    Crash Vray Sketchup
    renderpluginsextensions
    11 Posts 4 Posters 3.9k Views 4 Watching
      carconcal
      Hello, i have a problem.. i made a landscape with sketchup sandbox... then make a fur on it for grass..and i put some trees i found on the google warehouse....when i render it... it waits a large time and the it close sketchup without getting out the vray frame.... the curious thing is that when i hide the fur...it renders the trees..and the same if i hide the trees and render the fur....any idea for a solution???? jaja thankyou a lot
        ledisnomad
        Sounds like you don't have enough memory to process all those polygons. Both the fur/grass and the trees probably have a lot of polygons, so together it may be too much. Can you look in the Model Info window and see how many faces are in the model? And what are the specs on your computer?
          How much memory does Sketchup.exe consume right before it crashes?
          Also, what version of VfSU do you use? (Important info to include when asking questions.)
          And what SketchUp version do you use? SU8 Maintenance Release 1 allows you to use more memory if you have a 64bit OS.
            carconcal
            Thank you very much for taking your time answering my question...
            sorry ...i have a mac book pro ..core I7 with 8 GB in RAM....
            i am using google sketchup 8. and vray 1.49.01 the educational version...
            it haves....
            edges 1799147
            faces 522551
            components instance 26222
            thankyou again
              ledisnomad
              That's a sizeable model, but a good machine. I'm going to go with a corrupt texture map... don't know if it is still a problem with Vray 1.49.01, but that was the most common cause of crashes for me on the previous version(s).
              Easy test: in the Vray options, turn on the material override and render. If everything works, then it's most likely a texture map. If it renders, then try rendering a preview of one material at a time in the Vray Material Editor. The preview of the offending material often crashed my SU just like a full render did.
                carconcal
                Thankyou again...
                i click in global ssettings override materials...and it didnt render anything....
                the materials works well on the material editor... i never had this problem...
                thankyou
                  rojy1978
                  hi friend try this preset
                  https://rapidshare.com/files/2086861346/new.visopt
                  rojy
                    carconcal
                    here is the model image thankyou
                      ledisnomad
                      Is that an image of a Vray render or straight from SU? I think I'm out of ideas...
                        carconcal
                        sorry its an image direct from sketchup only to show the landscape model....it haves fur and trees...
                        the render never came out...i make what you say but it dosent work....what do you think can be?
                        thankyou very much for your time
                          carconcal
                          Rojy....i try with the visopt...and it didnt work...it didnt make the render...i think this problem is strange....thankyou for the vispot and your time...
