    How to mesure degrees please ?
    6 Posts 4 Posters 410 Views 4 Watching
    • E
      erzane
      hi
      I would like to make a room and I have a wall which is 49 degrees
      but I dont find the tool for draw it (I only have mesure in cm)
      thanks
      • TIGT
        Use the Protractor Tool to make a Guide-Line through the start point of the edge at the required angle [type it in]; draw over it with your new Lines...
        OR Draw a new Line and Select it - then use the Rotate Tool to rotate it by the required angle [type it in] - then continue drawing new Lines over/around it. Inferencing etc will align to it or perpendicular to it [=magenta]...
        • E
          erzane
          thanks a lot
          I made it
          pls can you tell me how to erase the help line ? if it's possible or not necessary if it will not influence the future ?
          http://img806.imageshack.us/img806/3160/capture01t.jpg
          • charly2008C
            charly2008
            Hi erzane,
            select the line and click the right mouse button and choose erase or del on the Keyboard.
            Charly
            • E
              erzane
              ok , thanks ; )
                Guide lines can also be deleted with Edit>Delete Guides. I use guides frequently enough that I set up a keyboard shortcut to delete them.
