    Resolution vray and sketchup
    renderpluginsextensions
    12 Posts 7 Posters 14.5k Views 7 Watching
    • F Offline
      fabrice de lyon
      Hello,
      I wish to render in V-ray and the image fit perfectly with a sketchup image, so the same camera, but I can not.
      Of course I changed the resolution in Vray, I tried to change the focal length of the camera, etc. ... It does not! There is always a lag. 😳
      How to have two images that stick well?
      Thank you for your help 😄
      http://lyon-en-1700.blogspot.fr/
        Exactly what version of VfSU do you use?
        • broomstickB Offline
          broomstick
          also check you are in perspective view, not in parallel view
          • F Offline
            fabrice de lyon
            I use the last version in demo 1.49.01
              Got a sample model?
              • jamalitoJ Offline
                jamalito
                if I want to print my render on A0 paper what is resolution I must put it on output they tell me 9000*14000 how I know what is resolution to output in vray ?
                my Vray is 1.49.01
                SU 8
                jamal
                Albert Einstein:
                ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                  It really depends on what you'll use it for. A0 prints are usually seen from larger distance than A4 and A3 and doesn't require the same DPI.
                  When you have determined the DPI you require for your print, then you use the size of the output format and the required DPI to calculate the image size in pixels.
                  http://forums.sketchucation.com/viewtopic.php?f=15&t=30474&start=0#p267562
                  • F Offline
                    fabrice de lyon
                    You can see my problem here.
                    It's a sketchup image and an alpha image from Vray.
                    I try to change the focal but... Same thing
                      If we can see a sample model we can have a look at your settings.
                      There should be no problem matching SU and VRay output, but some settings might throw things out.
                        ledisnomad
                        fabrice de lyon,
                        I think you might be working too hard: In Render Options > Output, are you using the "Get view aspect" button? And in Render Options > Camera, are you using the Default Camera or the Physical Camera? From my experience, those are the only two places that can affect whether or not the SU and Vray output line up.
                        • chonC Offline
                          chon
                          Hello,
                          for a perfect concordance, the 2 outputs (SU and VRay) might have exactly the same pixels size. I've made a test with standard physical camera and it works well... 👍
                          SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                          • V Offline
                            valerostudio
                            Yep, it looks like your aspect ratio is off a little bit. You need to unlock and reset it to match. Sometimes if you move a toolbar or add toolbars it changes your AR and you need to reset it to the correct ratio. Also, there is a current discussion on the V4S forums discussing the resolution your are talking about. 9000 pixels seems like overkill for anything that's not going to be published.
