    Is this possible with dynamic components?
    13 Posts 4 Posters 2.4k Views 4 Watching
    • jeff hammondJ Offline
      jeff hammond
      hi
      is something like this possible with dynamic components? i have something a bit more difficult in mind but if i can get this example to work then i should be able to apply it to the real deal.. if it's not possible, i'll go back to my avoid learning dcs for the next 6 months plan πŸ˜„
      thanks
      click pic for larger
      dotdotdot
        jeff hammond
        Must be trivial for a DC maker πŸ˜‰
        really? i hope so
        (and if it is in fact trivial.. can someone show me how to do it? please πŸ˜„)
        dotdotdot
            PS
            That don't work In normal su ?
            Draw one then
            Rescale (triangle surface + arc surface) by Scale πŸ˜‰
            Seems that works fine πŸ’š
              jeff hammond
              PS
              Draw one then
              nah, that doesn't work (the arc becomes elliptical etc..)
              but, point being, these exact shapes are easy enough to draw.. it's just if this is possible to do, i'll be able to take that and apply it to something that's much more time consuming to draw from scratch every time.
              dotdotdot
                I had a little doubt πŸ’š
                you can't make an abacus with usual measures where you just pick side's triangle, arc ?
                Else Tig will be very pleased to make a little ruby script in the old method πŸ˜‰
                Or are you just interested by the numeric results?
                  jeff hammond
                  depending on the situation, i'll use a couple of methods to draw these shapes.. one is with a fillet ruby and the other is like this:
                  click pic -> bigger
                  but again, i don't want to make this shape into a DC or ruby.. it's easy and fast to draw..
                  i'm just using it as an example to ask a question (the real example would be very confusing i imagine).. the thing is, if this simple example isn't possible then the DC i want to make definitely isn't possible.
                  dotdotdot
                    DCs have lots of suitable Math/Trig functions BUT the issue is that a DC can't magic new geometry out of thin air.
                    It can only adjust built-in parts - thus you can mimic a straight edge by having a sub-DC that is one edge and scaling it to suit BUT [as you might spot reading my True-Tangent and sibling scripts] there is complex calculation required to fillet two lines and whilst the edges up to the tangent point would be relatively easy to adjust the filleted arc itself is unique in every permutation of angles between those edges.
                    You can't 'scale' the arc except equally in the xy to adjust its radius for the same angle.
                    The 'start' and 'end' angles of the arc are potential so varied you cannot make a version for every combination...
                    Only if the edges to be filleted always meet at a one of a few angle sets then you can make an arc to suit one of those and adjust its radius using some convoluted math/trig... πŸ˜•
                      So maybe use an Excel file ? πŸ˜‰
                        jeff hammond
                        thanks tig.
                        yeah, i was thinking it wasn't going to work out right.. neither would the idea of having a few 'standard' sizes to choose from because what i'd like to do is take that then build make it even more dynamic.. (those input numbers would then affect the other radii further down the line etc..)
                        here's more of what i was hoping to do with a dynamic component [and even then.. this isn't all of the parts πŸ˜„]
                        dotdotdot
                          You will became a "press man button" against a ramp designer! πŸ˜‰
                          And after a skater can run on it with SketchyPhysic πŸ˜‰
                            jeff hammond
                            so, i got this to work πŸ€“
                            it's still just experimental because the arc is being created out of segments which are 3 levels deep so it's a bunch of exploding to get to the final face..
                            re: the other thread talking about using ruby commands in DCs.. do you think it's possible to put all the edges on one level?
                            select component -> component options
                            it has 4 inputs.. Radius, Angle, Height, & # of segments.. i'd like to be able to get the segments to be as near to 8" each as possible but i couldn't figure out how to do that in DC..
                            click pic -> bigger
                            [i'm just hyped that i finally got to use the geek emoticon πŸ˜„]
                            dotdotdot
                              Congrats Jeff. I've been following this discussion only because I wanted to say we lost another good man to code 😞
                              The great unwashed will welcome you back when you're ready πŸ‘
