    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 429.6k Views 172 Watching
    • bigstickB Offline
      bigstick
      Thanks Tomasz for explaining why I kept finding these leaf components in every single model!
      Pierreden, this is a really wonderful plugin, but it's not fully cooked IMHO. I accept that for some people it works fine, but there are lots of people still struggling with some aspects of it. For some it doesn't work at all, for others it has variable results.
      For me, the dialog works (it doesn't stay on top of the SU screen when I try to click to start growth, but it seems to work fine) but clicking in the model to start growth does nothing. Would it be worth creating a toolbar for this to start, and stop growth? The actual process of growing the ivy is the problematic thing for me. I have checked to see that all the required files are present, and everything seems normal. Is there some sort of debugging mode/action I can try?
      I don't mean to bitch, I would just really love this to work for not just me but for everyone else having difficulties. I'm very happy to help in any way I can if necessary.
      Context menu options to control growth might also be easier than remembering which key combinations to use. Oh, and a metric option. 😄
        tomasz
        Here is the 'LiveIvy_tool.rb' that needs to be replaced in the 'LiveIvy' folder to remove that annoyance.
        0.6.3+
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        • romboutR Offline
          rombout
          Hi tomasz,
          on the mac the popup window of ivy generator shows and than immediately hides again on the mac, su6 and 7
          Here's the code from SU7
          Error; #<NoMethodError; undefined method `to_array' for Pdn;;LiveIvy;;Parameters;Module>
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;58;in `register_callbacks'
          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/LiveIvy/LiveIvy_tool.rb;58;in `call'
          • romboutR Offline
            rombout
            @oxer said:
            @rombout said:
            how come for a lot of peeps the 0.6.3 versiion does work?
            on the mac i doesnt do anything, no feedback no nothing?! 😲
            Hi Rombout,
            Try this version, works for me on Mac OSX 10.6.7 and SU 8.
            Keys on Mac:
            Click where you want the Ivy to start grow.
            Cmd+Click : Make the ivy grow towards the mouse position.
            Alt+Click : Grow Ivy leafs.
            SHIFT+Click : Finish Ivy.
            Keyboard 'i' : Start over.
            [attachment=0:1xv8nygn]<!-- ia0 -->SketchupIvy.0.6.beta.zip<!-- ia0 -->[/attachment:1xv8nygn]
            He this version wont work no more for me any more. I did how ever did some updates on some plugins so think i need to do a reload step by step and see which one it is
            • OxerO Offline
              Oxer
              Hi Rombout,
              I use Sketchup 8 on Mac and Sketchupivy 0.6beta works fine for me, you can see this video on You Tube http://www.youtube.com/embed/RGV8jU9HK_Y
              If you want i send you the plugin again.
              Usually SketchyPhisics3 plugin gives errors and conflicts with other plugins like shape_bender.rb, round_corner.rb, Extrude Tools and others
              perhaps with Sketchupivy too, have you installed SketchyPhisics3?
              [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
              • charly2008C Offline
                charly2008
                I've recently experimented a bit to produce a Wisteria. Unfortunately I was not so successful. Then I have reinstalled the "0.63 beta". The result is now that no Ivy texture appears and Wisteria leaves also still appears. What is wrong?
                Charly
                • romboutR Offline
                  rombout
                  I do have a couple of those installed as well. But I think it due to the sketchy physics, I installed this lately and before that it was always working. But I got it to work again after changes to lines of code (see tomasz's tips) there's one doneside on that. I hardly renders leaves know!? So I think I need to take a closer look now.
                  What's also weird is that io never got your version to work in iether su7 or 8, I would only work in su6.
                    driven
                    Charley,
                    are the Materials showing up in the browser when you launch Ivy?
                    and does the script have Tigs mod??
                    john
                      charly2008
                      Hi John,
                      no, only the material for the tribe. Yes I have installed the "TIG mod".
                        driven
                        did you try it without the mod... john
                          charly2008
                          John,
                          yes i did. I have looked again at the contents of the texture folder (see pictures below). Can it be that something is missing here?
                          SKP-Files
                          Texture Files
                            driven
                            I think it's to do with the image file name, I remember re-naming a complete set to replace the originals when I was playing with it.
                            early in the thread someone supplied a modified Textures folder [with different leafs], maybe look at that...
                            john
                              charly2008
                              John,
                              I've tried the modified folder but no change. Even if the textures folder was deleted, wisteria, and ivy leaves appear the same. I do not understand, this is crazy!
                              Charly
                              Textures Folder deleted
                                charly2008
                                Dear members,
                                I need an idea from you. How can I eliminate this material Wisteria? I've searched the entire hard disk, but these "Wisteria.png" is nowhere to be found. But these png must be stored somewhere. I feel like a beginner.
                                Charly
                                  charly2008
                                  Problem solved. The png was saved in my template.
                                    charly2008
                                    I give it up now. Now the plugin is working again. But now some leaves are again transparent and others not. I probably do not understand the workings of this plugin. I'll wait for an update. 😢
                                    Charly
                                    • romboutR Offline
                                      rombout
                                      Charly
                                      THat's due to the prob that 2 images arent transparent png's open these to in a image editor and make them transparent and than re-import them into SU
                                        charly2008
                                        Hi Rombout,
                                        Thanks for your answer. I have converted the jpg to png. I do not know if I've done anything wrong. I have attached the pngs below. If you watch it once I would be grateful.
                                        Charly
                                          You seem to be going round in circles.
                                          This zip containing the three adjusted SKPs [and PNGs] that have hidden edges and already use proper transparent PNG files...
                                          Replace those in the Textures folder...
                                          Retry...IvyTexturesSKPs.zip
                                            charly2008
                                            TIG,
                                            I do not know how I can thank you. Sometimes you appear to me like the Robin Hood of the forum.
                                            Charly
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 36
                                            • 37
                                            • 18 / 37
