    [Plugin] VisTools
    69 Posts 21 Posters 71.6k Views 21 Watching
      You can try the translaters I used: http://www.thomthom.net/software/vertex_tools/translations
      • Dan RathbunD Offline
        Dan Rathbun
        Thanks go out to Defisto for proofing and editing the Spanish 'es' files !!!
        I'm not here much anymore.
          Dan Rathbun
          OK.. here's the basic hash template file:
          The 'XX' in the name needs to be replaced with a 2 char. language code.
          Within the file, change the "XX" hash values to the local translation.
          Please use parenthesis ( ) as I have, and punctuation periods, or '...' where I have, in the translations.
          Also repeat the use of capitalized words, as they are in the English keys.
          The %s params can be moved in the translated strings, to where they are more appropriate for the particular language.
          basic_utf8_XX.hash.txt
          Here is the template file for the debug strings.
          The technical terms should match those in the localized editions of Sketchup.
          debug_utf8_XX.hash.txt
            Dan Rathbun
            Added the "debug" string template file in the post above...
            see: http://forums.sketchucation.com/viewtopic.php?f=323&t=36465&p=350210#p350210
            • I Offline
              ishboo
              Great to see all this activity!
              SketchUp plugin marketplace: http://extendsketchup.com/
                I am on the road for the French language! 😉
                  I can do some Hungarian - need to install the plugin and see what it exactly does so that I understand why the expressions are what they are.
                  • I Offline
                    ishboo
                    Excellent!
                      limit=%s
                      I have translated the word "limit" by "limite" in French : must or not ? (I suppose yes 😄
                      Not yet tested 😳
                      you must rename them ...utf8_fr.hash.txt I suppose?
                        Dan Rathbun
                        Looks good... Thank you.
                        But... we need the Plugin Description in Francais, Si vous plaît:
                        "Adds some useful tools within SketchUp, like Hide / Show entities and layers, Freeze / Unfreeze for components, and Show / Unfreeze all."
                        Combination of Google & Microsoft Translators:
                        %(#8000BF)["Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Gel / Dégel pour des composants, et de Montrer / Dégeler tous."]
                        Sound OK ??
                          Quasi perfect 😉
                          "Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Geler / Dégeler pour des composants, et Montrer / Dégeler tous."
                            Dan Rathbun
                            OK.. thanks Pilou ... got and updated the file.
                            FEI (For Everyone's Information): I finally quit "fiddling" and sent Dana the "FreezeTools" ver 2.0.0 package, so he can have a first look. He'll likely put the package up on Github, until we are satisfied, that there are no major issues. Then he or I, will put the package on the EXTENDSketchup site.
                            Known "to do":
                            1. Reformat and expand the Help html file.
                            2. Tweak the "All" commands so they are correctly walking the nested groups / components, and performing their tasks the way they should.
                            3. Make sure if possible we do not have strange behavour during Undo and Redo operations.
                              Dan Rathbun
                              Note: Dana will be away till late next week (Thursday or so,) and will not be able to begin reviewing the new version til then.
                              Your patience is appreciated.
                              • I Offline
                                ishboo
                                Actually, I'll be back around the 5th of September 😕
                                  bimboombang
                                  THE ISOLATE LAYER DOESN'T WORK. i'M RUNNING SKETCHUP 8 PRO.
                                  Here's the ruby console errors.
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SU_Utils/Utilities.rb:241
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SU_Utils/Utilities.rb:45:in `call'
                                  Is there a fix or version 2.0 for skecthup 8 pro?
                                  Thanks. 😞
                                    Dan Rathbun
                                    First of all, the Active Layer cannot be hidden, so if you expected that, it will not happen.
                                    Isolate Layer seems to work OK in my v2.0.0 ...
                                    I had sent it to Dana for his approval, but he had just started a new job, and was heavily working on the ExtendSketchup plugin... so nothing has happened.
                                    Dana.. how about if we have TIG and/or ThomThom take a look ??
                                      If you have v1... zip downloaded from the direct link, then it doesn't contain the begin..rescue..end protection of the newer version that you can download manually from the site that is linked to 😕
                                      However, as even this could also jump out of the layer manipulation loop prematurely you can fix the tool's code thus...
                                      Edit the Utilities.rb file in the SU_Utils subfolder, using Notepad or a similar plain text editor like Notepad++...
                                      Use its 'Find and Replace' tool to change the two lines of code that say
                                      l.visible = false
                                      with this
                                      l.visible = false **unless l == @model.active_layer**
                                      This will stop you trying to make the active layer invisible which is disallowed...
                                      Save it and restart Sketchup.
                                      Now the two layer tools that try to switch layers 'off' should work without errors...
                                      • I Offline
                                        ishboo
                                        Thanks Dan/TIG for replying! You guys rock.
                                          dbehrens9000
                                          Ishboo,
                                          I use this utility alot with large projects and it no longer works with sketchup 8.0.15158. Could you please check why it does not load? Was there a change in the sdk that conflicts with your ruby scrpit?
                                          Many thanks,
                                          David
                                          • I Offline
                                            ishboo
                                            @dbehrens9000 said:
                                            Ishboo,
                                            Many thanks,
                                            David
                                            Hi David, I will look into and get back to you. I've been working on re-writing the application recently. Will update!
                                            • 2 / 4
