    [Plugin] VisTools
    69 Posts 21 Posters 66.6k Views 21 Watching
      limit=%s
      I have translated the word "limit" by "limite" in French : must or not ? (I suppose yes 😄
      Not yet tested 😳
      you must rename them ...utf8_fr.hash.txt I suppose?
      basic_utf8_XX.hash.txt
      debug_utf8_XX.hash.txt
      • Dan RathbunD Offline
        Dan Rathbun
        Looks good... Thank you.
        But... we need the Plugin Description in Francais, Si vous plaît:
        "Adds some useful tools within SketchUp, like Hide / Show entities and layers, Freeze / Unfreeze for components, and Show / Unfreeze all."
        Combination of Google & Microsoft Translators:
        %(#8000BF)["Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Gel / Dégel pour des composants, et de Montrer / Dégeler tous."]
        Sound OK ??
        I'm not here much anymore.
          Quasi perfect 😉
          "Ajoute quelques outils utiles dans SketchUp, comme Cacher / Montrer des entités et des calques, Geler / Dégeler pour des composants, et Montrer / Dégeler tous."
            Dan Rathbun
            OK.. thanks Pilou ... got and updated the file.
            FEI (For Everyone's Information): I finally quit "fiddling" and sent Dana the "FreezeTools" ver 2.0.0 package, so he can have a first look. He'll likely put the package up on Github, until we are satisfied, that there are no major issues. Then he or I, will put the package on the EXTENDSketchup site.
            Known "to do":
            1. Reformat and expand the Help html file.
            2. Tweak the "All" commands so they are correctly walking the nested groups / components, and performing their tasks the way they should.
            3. Make sure if possible we do not have strange behavour during Undo and Redo operations.
              Dan Rathbun
              Note: Dana will be away till late next week (Thursday or so,) and will not be able to begin reviewing the new version til then.
              Your patience is appreciated.
              • I Offline
                ishboo
                Actually, I'll be back around the 5th of September 😕
                SketchUp plugin marketplace: http://extendsketchup.com/
                  bimboombang
                  THE ISOLATE LAYER DOESN'T WORK. i'M RUNNING SKETCHUP 8 PRO.
                  Here's the ruby console errors.
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SU_Utils/Utilities.rb:241
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SU_Utils/Utilities.rb:45:in `call'
                  Is there a fix or version 2.0 for skecthup 8 pro?
                  Thanks. 😞
                    Dan Rathbun
                    First of all, the Active Layer cannot be hidden, so if you expected that, it will not happen.
                    Isolate Layer seems to work OK in my v2.0.0 ...
                    I had sent it to Dana for his approval, but he had just started a new job, and was heavily working on the ExtendSketchup plugin... so nothing has happened.
                    Dana.. how about if we have TIG and/or ThomThom take a look ??
                      If you have v1... zip downloaded from the direct link, then it doesn't contain the begin..rescue..end protection of the newer version that you can download manually from the site that is linked to 😕
                      However, as even this could also jump out of the layer manipulation loop prematurely you can fix the tool's code thus...
                      Edit the Utilities.rb file in the SU_Utils subfolder, using Notepad or a similar plain text editor like Notepad++...
                      Use its 'Find and Replace' tool to change the two lines of code that say
                      l.visible = false
                      with this
                      l.visible = false **unless l == @model.active_layer**
                      This will stop you trying to make the active layer invisible which is disallowed...
                      Save it and restart Sketchup.
                      Now the two layer tools that try to switch layers 'off' should work without errors...
                      • I Offline
                        ishboo
                        Thanks Dan/TIG for replying! You guys rock.
                          dbehrens9000
                          Ishboo,
                          I use this utility alot with large projects and it no longer works with sketchup 8.0.15158. Could you please check why it does not load? Was there a change in the sdk that conflicts with your ruby scrpit?
                          Many thanks,
                          David
                          • I Offline
                            ishboo
                            @dbehrens9000 said:
                            Ishboo,
                            Many thanks,
                            David
                            Hi David, I will look into and get back to you. I've been working on re-writing the application recently. Will update!
                            • I Offline
                              ishboo
                              I've finished a new release of the plugin. I've renamed it to VisTools so it's not so confusing and ambiguous.
                                Dan Rathbun
                                So you are settling on "IntrepidBear" as your toplevel namespace and filespace, then ?
                                • utilerU Offline
                                  utiler
                                  Hi Dana, nice clean set of Utilities.. well done and thank you on behalf of everyone who has downloaded it!!
                                  I had a think about the Isolate Entitles: its great to be able to isolate something particularly in a large model when you want to just work on that specifically however it would is just as important to be able to revert back to the entities that were visible. The same applies to the Hide Entities tool: mostly I would think that once you've finished with the hiding what you need you'd want the option to revert back....
                                  Just a thought
                                  Thank you again. 👍
                                  Just Curious...
                                  • I Offline
                                    ishboo
                                    Just a thought
                                    Thank you again. 👍
                                    Glad you like the tool!
                                    If I understand correctly, you're asking for the ability to "unhide all" which is actually a button on the menu, so you should be able to do that already. I apologize if I'm misunderstanding what you're looking for.
                                    • utilerU Offline
                                      utiler
                                      Thanks for the reply, Dana.
                                      I see you have an 'unhide all' botton in the toolset but what I was thinking was if I isolate selected entities I would like to then go back to what I had shown before I did so, not necessarily unhiding all.
                                      Just Curious...
                                      • atelierpaarA Offline
                                        atelierpaar
                                        Hi there,
                                        This seems to be a great tool and i would like to test it.
                                        I try to figure out how to install "Vistools".
                                        After downloading and unpacking the zipfile SU responses with the following Error message :
                                        no such file to load-C/Programfiles (x86)/Google/GoogleSketchup8/Plugins/IntrepidBear/Vistools/VisTools.rb
                                        After checking the zip -file, I found that the folder "IntrepidBear" misses the subfolder "Vistools" as well as "VisTools.rb "
                                        Where ist the problem ?
                                        thanks for your help
                                        Uli
                                          Usually it is you, "the user", who has managed to mess up a tool's download and installation... BUT in this case it is in no way your fault ! 😮
                                          Something does indeed seem very awry ! 😲
                                          Both the current download-able ZIP and RBZ versions on Dana's site contain an empty 'IntrepidBear' folder.
                                          This ought to contain a 'Vistools' subfolder, which in turn ought to have VisTools.rb and probably some other files in there too 😒
                                          I'm sure Dana can fix this... If you get no response/fix after a reasonable time - then nag him - perhaps by PM...
                                          • I Offline
                                            ishboo
                                            Sorry bout the broken download zip, I've fixed it.
                                            Had made the zip on the command line and apparently my settings only zipped the folders, doh!
                                            Gotya. Like an "undo" button? I could look into adding this, just not sure when I'd have the time to get around to it! 😕
                                            Could be added with some sort of "history" buffer...
                                            • 2 / 4
