ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Plugin Request: Hide Bounding Box
13 Posts 10 Posters 3.4k Views
  • F Offline
    function
    I'm looking for a command to hide the bounding box - similar to ctrl-H in photoshop, which hides the blinking marquee selection. At times the bounding box can be visually distracting, and a toggle to turn it on/off would make some moves much easier to make design decisions! Sketchup supports coloring of the bounding box - possibly opacity of this color is hidden in the API? 😎
      The bounding box is colored to match your highlight color set in the current Style.
      It can only be a color, with no transparency allowed.
      If you set your highlight color to 'white' the bb becomes less obtrusive, but then selected object's color becomes much less obvious... 😞
      • F Offline
        function
        that's disappointing
        most major graphics packages have this feature in conjunction with the main tools; using illustrator tonight - it is simply ctrl, (alt-move is copy 😲 ) I believe designers see the value of hiding all information except the element in creation or modification. Sketchup is certainly a design tool ..
        I have been changing the bounding box to the material color as you mentioned, which is a good compromise - possibly something could be made that toggles BoundingBox to selected materials color, or layer color - πŸ‘ doesn't work too well with the blinding neon green scale grabbers though πŸ˜’
          The only feature SU has in that area is being able to display only Boundingbox - and not highlight the selected entities.
          • G Offline
            What is the exact reason you want to do this? The bounding box is generally only interesting when modelling so I cannot imagine anything particular it could be hindering you in.
            • F Offline
              function
              it can be visually impeding when making minute adjustments - especially when adjusting negative space, - details at edges become much more apparent - I'm not sure how else to illustrate it, but I use it all the time in other design apps πŸ˜„
              • G Offline
                gonashvili
                I would also be interested to know this. It woulda be easier to see things, especially when arranging/moving symmetrical components [how they "touch together"]...
                    Yeah but try it with any shape that is not a perfect box and the bounding box is much more visible.
                    I admit it has never bothered me, but I can see how it could bother others.
                    All my Plugins I've written
                      It doesn't bother me, either.
                        DesertRaven
                        It has always bothered me.
                        The bounding box is always like this blur of extra lines that are not exactly but very close to the selected edges. And yes it makes working fast and with precision a chore.
                        How many times have I worked with Models where team members had just missed the precise position and how many hours of unnecessary work have I spent finding and fixing errors due to this display obscurance?
                        I can't see any reason at all why there wouldn't be a function to turn them off.
                        To those of you who are not bothered by the bounding box, why would it bother you if anyone else could just turn it off and be happy?
                        And how much effort would it take to add the function?
                        Edit: How about replacing the bounding box with a feature that just highlights the faces of the selected object, and maybe the actual edges, with the color chosen in the styles?
                        simplicity is the ultimate sophistication
                        • O Offline
                          otb designworks
                          Another vote for being able to turn it on and off with a hot key.
                          I find the bounding box distracting and mostly unnecessary; especially when editing groups/components.
                          just my $0.02
                          Cheers, Chuck
                          OTB Designworks is on Youtube
                          • P Offline
                            pibuz
                            Adding my kind upvote for this!!!
                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
