    Offsetting Existing Faces Within a Building?
    3 Posts 2 Posters 271 Views 2 Watching
    • Mistro11M Offline
      Mistro11
      Is it possible to offset an existing wall? I have the exterior done and I also want to do some work in the interior but I did not offset the walls in the beginning because I used the match new photo method. The building has 2 stories and I want to create interior faces. Is it too late or is there a known method to solve this? Thanks in advance.
      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
        A simple 'PushPull' will 'offset' a face by the amount you either pick-to OR type-in.
        To make multiple faces offset in one go you could try JointPushPull script...
        • Mistro11M Offline
          Mistro11
          I think I have it sorted. I selected one floor at a time (the bottom of each room) and did an offset. I then selected the middle sections and Push/pulled them up. I now have thick walls to work with.Thanks.
