    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.1k Views 107 Watching
      tak2hata
      @vilcoyote57 said:
      Hi, great plugin.. but I can't understand how EXCHANGE tool works. Can you help me? thanks
      Hi,vilcoyote57.
      "EXCHANGE" is not work well yet.
      How to use.
      1.Select the group / component that is solid.
      2.Click "EXCHANGE".
      3.Select "Type" in dialog.
      It is all.
      The longest edge of the group/ component is used to length about element of building structure.
      Thanks.
      by TAK2HATA
        SUFractal
        @millzye71 said:
        Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
        Cheers
        Millzye
        Couldn't you draw a 'wire frame' (for lack of a better way of saying it) then use the desired steel section tool to 'trace' along the wireframe line?
          SUFractal
          tak2hata:
          I've been working with your wonderful BuildingStuctureTools plugin recently. Are you planning on creating any additional tools (and icons) for your plugin?
          Although it appears relatively easy to add additional profiles to the existing tools you've created, I think it would be even more convenient if there were separate tools for things such as:
          "flanged" steel columns the (H-shapes as you've named them)
          round steel columns
          steel angles (L-shapes)
          steel channels ([-shape)
          C-shape steel (these appear to be steel studs)
          T-shaped steel
          flat bars
          By adding more tools, the list for each tool would not be quite so long in the window menu that pops up. For example, instead of just one "steel column" tool, having one (with its icon) for each shape "type" (H, round, square) would be easier/faster to find the structural member needed.
          Thanks,
          SUFractal
            tak2hata
            @sufractal said:
            tak2hata:
            round steel columns
            T-shaped steel
            flat bars
            Thanks,
            SUFractal
            Hi,SUFractal.
            I will create new dialog with WEBDIALOG.
            It will be more convinient.
            Please wait.
            Now,Searching with word like "H-100" to use icon "Dialog ALL".
            Click the icon ,InputBox"Search" will show.
            It will show limiting items in listbox.
            Thanks.
            by TAK2HATA
              SUFractal
              @tak2hata said:
              @sufractal said:
              tak2hata:
              round steel columns
              T-shaped steel
              flat bars
              Thanks,
              SUFractal
              Hi,SUFractal.
              Please wait.
              Thanks.
              Sounds great! Thank you.
              • guanjinG Offline
                guanjin
                The tool is very useful, language translation of documents, can not be displayed correctly
                I come from China, is to learn
                • beginnerB Offline
                  beginner
                  Hi There,
                  The plugin is great.
                  I have only one problem with the 'default_pflist.csv' file.
                  The editing of the file doesn't take any effect in SketchUP.
                  Is anybody successfully added any new 'sizes'?
                  I would appreciate your comments.
                  Regards
                  Regards, SU 'beginner'
                    SUFractal
                    @beginner said:
                    Hi There,
                    Regards
                    Did you change the contents (sizes) within that file?
                    • beginnerB Offline
                      beginner
                      Hi There,
                      I have seen the tutorial http://www.youtube.com/watch?v=oSVrbJMSSB0&feature=player_embedded and I have noticed that you can change the path to the *.csv file.
                      I have created a new file, located on My Desktop and changed the path - it works! but... when I change to the plugins path it doesn't.
                      Never mind, I like the fact that you can link own *.csv file and it can seat in my preferred location.
                      Thank you
                      Regards
                        SUFractal
                        @beginner said:
                        Hi There,
                        Thank you
                        Regards
                        I don't know this to be 100% true, but I suspect that file does not belong on your desktop, but probably within the "building_structure_tool" folder located inside your plugins folder. Give it a try and see if that corrects the problem.
                        • beginnerB Offline
                          beginner
                          @sufractal said:
                          Hi There,
                          You are right the file does not belong to the Desktop - it is my copy of the file from ...\Plugins\building_structure_tool folder to play with.
                          As I said - When I edit the file in the plugins folder I don't see any changes in SketchUP but...
                          When I edit the file on my desktop (outside the plugin folder - you can keep the copy of the file anywhere you like) and change the path in SketchUP I can see the changes (picture attached).
                          Path to the default_pflist.csv - now I will change to my Desktop copy and I will see my new steel, walls etc. types
                          • G Offline
                            go45454
                            thankkkkkkkk
                            • brookefoxB Offline
                              brookefox
                              tak2hata, Thanks very much for this promising set of tools. I hope you find the time to make the videos larger and maybe more complete.
                              I tried copying and slightly altering the wall to have a baseboard on both sides but this seems to 'break' the proper corner corrections you have made the program perform. I see all your multi-walls are one sided; do they have to be? Could the standard application methods be adapted to trimming around window or door openings?
                              ~ Brooke
                                sags
                                thanks... 👍
                                  josephcase
                                  I apologize if this is not correct area,
                                  I need help.. I'm tasked to create two different
                                  size CORRUGATED MULTI-PLATE pipes. The first has dia
                                  of 9'6" IS using total 6 plates @5 gage to complete 1 ring. The
                                  second is 16' IS using 8 plates @5 gage. It appears that your
                                  toolkit allows making FLAT roofing products EXCELLENT! Can
                                  it make the sections I need for circular multi plate corrugated pipe?
                                  The holes and length/width are no issue but curved as opposed to
                                  flat is. Please advise or point to tutorial for topic. Thanks Joe
                                    tak2hata
                                    Hi,Joe.
                                    I think that your proposal is difficult in this plugin.
                                    I think Chris Fullmer's Shape Bender is help you.
                                    http://forums.sketchucation.com/viewtopic.php?t=18210#p147395
                                    Hi,SU Fractal and Beginer.
                                    The File System of ruby in sketchup(windows) can not work well with path include the original characters of the language.
                                    I tried the many method ,but I could not find good solution.
                                    So the csv file about profile list locate the suitable folder whitch do not include the special characters.
                                    This is as hard as possible.
                                    Thanks.
                                    by TAK2HATA
                                      SUFractal
                                      tak2hata:
                                      Today (all of a sudden) the "steel column" tool stopped working. All of the other tools appear to be working fine. I have not changed any of the scripts or files associated with this plugin for quite a while.
                                      When I click on the steel column icon, a window for selecting member sizes does not appear.
                                        tak2hata
                                        @sufractal said:
                                        tak2hata:
                                        Hi,SUFractal.
                                        well,I do not have a point to which it occurs.
                                        So I want to see the ruby console on your sketchup.
                                        Show "Ruby console" from "Window" menu.
                                        Start Building structure tool"Steel Column".
                                        Copy the message shown in ruby console.
                                        And post it.
                                        I will see and consider the problem.
                                        by TAK2HATA
                                        • kenK Offline
                                          ken
                                          @sufractal said:
                                          tak2hata:
                                          This has happen to me also. I found that if you go to the plugin menu and clear defaults it will start working again. At least on my computer that works.
                                          Ken
                                            SUFractal
                                            @sufractal said:
                                            tak2hata:
                                            Ken
                                            Genius! Thank you Ken, it worked.
                                            • 6
                                            • 7
                                            • 8
                                            • 16
                                            • 17
                                            • 6 / 17
