    [Plugin] QuadsFrom2Tris v1.3 20110312
    13 Posts 2 Posters 11.5k Views 2 Watching
    • TIGT Online
      TIG (c) 2011
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Plugin:
      QuadsFrom2Tris.rb >> Plugins folder
      Usage:
      Plugins menu >> "Quads From 2 Triangles..."
      Result:
      Processes 2 preselected connected triangles into 5 quads, with a central
      hub-diamond placed just above/below the common-edge depending on
      convex/concave surfaces.
      If the 2 triangles are coplanar they are combined into 1 quad.
      The Triangle's Materials and Layers are preserved.
      or use in other code as
      QuadsFrom2Tris.new() or quadsfrom2tris()
      Without arguments it needs 2 preselected triangular faces, or use as
      QuadsFrom2Tris.new([tri1, tr2]) or quadsfrom2tris([tri1, tr2])
      where tr1 and tr2 are the two connected triangular faces.
      Donations:
      By Paypal.com to info @ revitrev.org PayPalButton Version:
      1.0 20110310 First issue.
      1.1 20110310 Reversed faces glitch etc fixed.
      1.2 20110311 Off of 'hub' optimized.
      1.3 20110312 Occasional glitch with some configurations addressed.
      QuadsFrom2Tris.rb
        πŸ‘
        Amazing no one ever thought of this before?
        • TIGT Online
          I was nudged into it by some PM nagging πŸ˜‰
            Wish GRANTed! Lucky member who it was?
            • TIGT Online
              I don't exactly remember the member... but I think he sounds wealthy πŸ˜‰
              • TIGT Online
                I've just finished testing it... and in some circumstances I've found that it can reverse some faces and mess up concave surfaces... I'm already working on an update πŸ˜’
                • TIGT Online
                  Here's v1.1
                  The reversed faces glitch etc have been fixed.
                  http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                  • TIGT Online
                    Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                    The offset of the 'hub' has been [re]optimized...
                      TIG,
                      I first ran it on the opposite side to this and it worked perfect. Did the other side and this is the result...
                      http://www.dropmocks.com/iSRnM
                      Nothing in Ruby Console if that helps?
                      • TIGT Online
                        TIG,
                        Strangely when I run it on the SKP you provided before I get perfect results on BOTH sides πŸ˜•
                        Can you retry and PM me the problem SKP if it keeps happening. I can't see how this might happen ? πŸ˜’
                          TIG_Error.skp
                          This actually does it on both sides πŸ˜•
                          • TIGT Online
                            Here is v1.3 http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                            This now successfully works even on the configuration supplied by Rich [I still can't see why it was failing... BUT it seems like it intersected with a ghost of part itself - weird - πŸ˜• - this new version avoids this issue by making sure there are no coplanar edges at a crucial stage in the reforming πŸ˜’ ]
                            It's now a bit like 'Aspirin' - it is efficacious, but no one is sure exactly 'how' πŸ˜‰
                              Works fine, trying my hardest to break it.. πŸ‘
