    [Plugin] QuadsFrom2Tris v1.3 20110312
    13 Posts 2 Posters 11.4k Views 2 Watching
      πŸ‘
      Amazing no one ever thought of this before?
        I was nudged into it by some PM nagging πŸ˜‰
          Wish GRANTed! Lucky member who it was?
            I don't exactly remember the member... but I think he sounds wealthy πŸ˜‰
              I've just finished testing it... and in some circumstances I've found that it can reverse some faces and mess up concave surfaces... I'm already working on an update πŸ˜’
                Here's v1.1
                The reversed faces glitch etc have been fixed.
                http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                  Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                  The offset of the 'hub' has been [re]optimized...
                    TIG,
                    I first ran it on the opposite side to this and it worked perfect. Did the other side and this is the result...
                    http://www.dropmocks.com/iSRnM
                    Nothing in Ruby Console if that helps?
                      TIG,
                      Strangely when I run it on the SKP you provided before I get perfect results on BOTH sides πŸ˜•
                      Can you retry and PM me the problem SKP if it keeps happening. I can't see how this might happen ? πŸ˜’
                        TIG_Error.skp
                        This actually does it on both sides πŸ˜•
                          Here is v1.3 http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                          This now successfully works even on the configuration supplied by Rich [I still can't see why it was failing... BUT it seems like it intersected with a ghost of part itself - weird - πŸ˜• - this new version avoids this issue by making sure there are no coplanar edges at a crucial stage in the reforming πŸ˜’ ]
                          It's now a bit like 'Aspirin' - it is efficacious, but no one is sure exactly 'how' πŸ˜‰
                            Works fine, trying my hardest to break it.. πŸ‘
