    [Plugin] QuadsFrom2Tris v1.3 20110312
    13 Posts 2 Posters 11.4k Views 2 Watching
      TIG (c) 2011
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Plugin:
      QuadsFrom2Tris.rb >> Plugins folder
      Usage:
      Plugins menu >> "Quads From 2 Triangles..."
      Result:
      Processes 2 preselected connected triangles into 5 quads, with a central
      hub-diamond placed just above/below the common-edge depending on
      convex/concave surfaces.
      If the 2 triangles are coplanar they are combined into 1 quad.
      The Triangle's Materials and Layers are preserved.
      or use in other code as
      QuadsFrom2Tris.new() or quadsfrom2tris()
      Without arguments it needs 2 preselected triangular faces, or use as
      QuadsFrom2Tris.new([tri1, tr2]) or quadsfrom2tris([tri1, tr2])
      where tr1 and tr2 are the two connected triangular faces.
      Donations:
      By Paypal.com to info @ revitrev.org PayPalButton Version:
      1.0 20110310 First issue.
      1.1 20110310 Reversed faces glitch etc fixed.
      1.2 20110311 Off of 'hub' optimized.
      1.3 20110312 Occasional glitch with some configurations addressed.
      QuadsFrom2Tris.rb
        πŸ‘
        Amazing no one ever thought of this before?
          I was nudged into it by some PM nagging πŸ˜‰
            Wish GRANTed! Lucky member who it was?
              I don't exactly remember the member... but I think he sounds wealthy πŸ˜‰
                I've just finished testing it... and in some circumstances I've found that it can reverse some faces and mess up concave surfaces... I'm already working on an update πŸ˜’
                  Here's v1.1
                  The reversed faces glitch etc have been fixed.
                  http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                    Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                    The offset of the 'hub' has been [re]optimized...
                      TIG,
                      I first ran it on the opposite side to this and it worked perfect. Did the other side and this is the result...
                      http://www.dropmocks.com/iSRnM
                      Nothing in Ruby Console if that helps?
                        TIG,
                        Strangely when I run it on the SKP you provided before I get perfect results on BOTH sides πŸ˜•
                        Can you retry and PM me the problem SKP if it keeps happening. I can't see how this might happen ? πŸ˜’
                          TIG_Error.skp
                          This actually does it on both sides πŸ˜•
                            Here is v1.3 http://forums.sketchucation.com/viewtopic.php?p=315130#p315130
                            This now successfully works even on the configuration supplied by Rich [I still can't see why it was failing... BUT it seems like it intersected with a ghost of part itself - weird - πŸ˜• - this new version avoids this issue by making sure there are no coplanar edges at a crucial stage in the reforming πŸ˜’ ]
                            It's now a bit like 'Aspirin' - it is efficacious, but no one is sure exactly 'how' πŸ˜‰
                              Works fine, trying my hardest to break it.. πŸ‘
