    Invisible Material
    renderpluginsextensions
    11 Posts 7 Posters 4.7k Views 7 Watching
    • focptF Offline
      focpt
      Greetings,
      I discovered how to render materials invisible, but with shadows still showing. This would be helpful for situations where you want to add trees in photoshop post process.
      Cheers,
      ta-da!
      • Nathan
        http://www.focalpointstudio.net
      SU8, VRay 1.49
      • ToboboT Offline
        Tobobo
        Thats Brilliant!!! ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
        How did you find that out?
        Toby
        Philippians 4:13
        • focptF Offline
          focpt
          Just some experimentation. Really, I started randomly pressing buttons like a monkey - rendering each time.
          • Nathan
          SU8, VRay 1.49
            Note that the material will be visible in reflections and refractions.
            • focptF Offline
              focpt
              Right, so in a window you would see the reflection of that green cartoon tree.
              • Nathan
              SU8, VRay 1.49
                AcesHigh
                what about the checkbox right below that one? (Exclude All Materials from Reflection/Refraction)
                • andybotA Offline
                  andybot
                  @AcesHigh
                  indeed, the exclude materials checkbox works pretty well. First image
                  original
                  Here is the option of visible only in secondary for the tree material
                  tree material hidden
                  The mirror material has the exclude materials from relfection/ refrac. option checked (optimize exclusion didn't seem to make any difference)
                  invisible
                  • focptF Offline
                    focpt
                    Thanks Andybot for completing the experiment. Now we know.
                    • Nathan
                    SU8, VRay 1.49
                      tovel
                      Hello,
                      I have v-ray to Sketch-up 7,
                      I canยดt find the option "only visible in secondary"
                      in the material editor. Could it be I have an old version?
                      • focptF Offline
                        focpt
                        @tovel said:
                        Hello,
                        What version do you have? Latest is 1.49.x
                        • Nathan
                        SU8, VRay 1.49
                        • F Offline
                          fjrentas
                          The problem with exclude object form the reflection is that you will exclude all the object.
