    3D vs. Billboard Trees and People
    renderpluginsextensions
    28 Posts 7 Posters 7.6k Views 7 Watching
    • focptF
      focpt
      I'm really pulling my hair out trying to figure out the best way to handle entourage. I have tried post process only with photshop. I have tried photo billboards in the model. Neither is working well. Nothing ruins an illustration (and is easy to spot) than bad people and trees.
      So my question is: what is everyone's approach to people and trees?
      Thanks in advance,
      Nathan
      • Nathan
        http://www.focalpointstudio.net
      SU8, VRay 1.49
      • thomthomT
        I feel your pain. Getting vegetation is much easier. There's lots of good quality imagery there.
        What I find troublesome is people, very hard to find casual people that fits discreetly into an image. Too much of the resources feature people who do silly poses - in a adverticement-cliche kind of pose. 🤢
        I'm trying to find a real good quality resource for this where I can make the office purchase a package. Finding quality free stuff wastes too much time. (at least my attempts...)
        • srxS
          srx
          In my expiriance this is the best solution http://www.lowpolygon3d.com/index.php?app=cms&ns=display&ref=splash&sid=iz68x2ua9k3t782la7028e59727p8j22&portrelay=1
          Here is the free sample converted to skp format
          Low polygon man.zip
          www.saurus.rs
          • thomthomT
            Doesn't work well for close ups. But these can be very good from a little distance. And it might solve my problem when it comes to birds-eye view scenes.
            90€ for 8 characters? Or is it more in the packages?
            • srxS
              srx
              U can always use this http://sketchup.google.com/3dwarehouse/search?q=lowpolygon+3d+people&styp=m&btnG=Search&reps=1
              http://sketchup.google.com/3dwarehouse/details?mid=5b99b2e51f56c90f1dbf46aef359e874&ct=mdsa&prevstart=0
              www.saurus.rs
              • focptF
                focpt
                Thanks for the LowPoly Man (sounds like a blues song), I will have to check that in a VRAY rendering tonight at various distances, eye level, etc.
                What do you guys do for placing billboards?
                A. create cut-out components out of images and place them in sketchup, then render
                B. Use photoshop to paste images post process. If so, how do get them scaled correctly and how do you add shadows.
                Or is there some composite way? I have tried using a 3D tree then overlaying an image on top of it post-process. That way I get the depth and shadows in my final illustration. However, to that I have to set up an alpha channel for the tree, etc. etc...very time consuming.
                • Nathan
                SU8, VRay 1.49
                • thomthomT
                  I usually do this. It add shadows and ensures things get scaled properly. Plus it reduce the amount of masking in PS.
                  When I add people in post I use a reference export from SU where I've placed some silhouette people for references.
                  • focptF
                    focpt
                    ThomThom,
                    I'm sure you are aware, but http://www.turbosquid.com/ has some nice bundles. I have purchased a couple for offices in the past.
                    Is there a way to 'bake' in the shadows (this can be done in 3ds max)? That way I could get the shadows from 3d trees on one layer, then do the final render with image billboards.
                    • Nathan
                    SU8, VRay 1.49
                    • daleD
                      dale
                      I appreciate this discussion. I usually end up leaving the scenes void because quite frankly every time I add entourage it looks phony.
                      I'll follow any lead suggested.
                      • focptF
                        focpt
                        Currently my thoughts are:
                        People:
                        A. Clipped Images.
                        Use really nice clipped images, turned into face-me billboards. Being careful to find images that have 'neutral light' on them.
                        Pros: no photoshop time
                        Cons: flat appearance, doesn't work from birds-eye, time consuming to build these.
                        B. Low-poly people with textures.
                        Pros: no photoshop time, works from birds-eye, true depth
                        Cons: doesn't work up close, hard/expensive to find a large number of good ones.
                        C. High-poly people with textures.(does this exist for SU?)
                        Cons: doesn't work up close, hard/expensive to find a large number of good ones, slows computer
                        D. Place holder billboards, photoshop people on top of place holder
                        Pros: easy to add large variety of people images
                        Cons: Post process time, lighting may not look right.
                        Trees:
                        A. Clipped Images.
                        Use really nice clipped images, turned into face-me billboards.Use really nice clipped images, turned into face-me billboards. Being careful to find
                        B. High-poly Trees
                        Cons: doesn't work up close, hard/expensive to find a large number of good ones, slows computer, very hard to find range of species, very few look organic and realistic
                        C. Mid-poly Trees with post process.
                        Use Mid-poly trees to accomplish depth and shadow. In photoshop, overlay real images on top of mid-poly trees.
                        Pros: Realistic (?)
                        Cons: Lots of post process time, hard to accomplish with a grove of trees
                        • Nathan
                        SU8, VRay 1.49
                        • L
                          ledisnomad
                          It's not a one-size-fits-all solution (doesn't work for overhead at all), but I like the long exposure style photographs where the people are blurred. I've had good success with this technique because it requires very little accurate detail on the people. I use some of the cut-out photo people from the 3D Warehouse, copy them onto a new layer in Photoshop and use the motion blur filter. Like I said, not a universal solution.
                          Speaking of no universal solution, maybe a list of techniques and/or do's and don'ts for different situations would be helpful. Here's a very quick start. Please edit:
                          I. Eye-level:
                          a. Close-up
                          - NOT low-poly 3D
                          - Long-exposure style blurred 2D photo people
                          b. Distant
                          - 2D photo people (there are some in the 3D Warehouse)
                          - 2D sillouettes as reference to post-pro
                          - Low-poly 3D
                          c. Crowded
                          - Post-pro in foreground, low-poly 3D in background?
                          d. Sparse
                          - Very, very careful Photoshop?
                          II. Overhead:
                          - Low-poly 3D people
                          - NOT 2D people
                          - Post-pro only may be too time consuming?
                          • thomthomT
                            +1 ledisnomad!
                            • daleD
                              dale
                              Someone I believe is very tasteful in his use of entourage is Free Agent. http://forums.sketchucation.com/viewtopic.php?p=254467#p254467
                              If I am not mistaken he uses photoshop post pro for his work.
                              He seems to have uncanny taste in the numbers and placement of the people he uses.(IMHO)
                              There are examples in the above links of closeup, overhead, and distant use.
                              • focptF
                                focpt
                                Good thoughts ledisnomad. Entourage Guidelines are excatly what I'm trying to develop for my work flow.
                                @ledisnomad said:
                                d. Sparse
                                Do you mean just free-hand pasting in photoshop without any reference?
                                Cheers,
                                Nathan
                                • Nathan
                                SU8, VRay 1.49
                                • thomthomT
                                  Yes - he's got a very nice style. Too bad he's not been very active lately. 😞
                                  • focptF
                                    focpt
                                    Second that. I would like to hear Free Agent's thoughts.
                                    • Nathan
                                    SU8, VRay 1.49
                                    • focptF
                                      focpt
                                      Look closely at the first images (African Market). The raw rendering has shadows from a tree, but the tree doesn't render. How is this done??!! That could be helpful. Is this an option in VRay or was that from Max?
                                      • Nathan
                                      SU8, VRay 1.49
                                      • daleD
                                        dale
                                        I sent him a PM asking him if he would mind explaining his workflow. I'm hoping he will jump in.
                                        • free agentF
                                          free agent
                                          Hey presto!!
                                          my thoughts on entourage is: photoshop photoshop photoshop. i only ever use 3d people for distant aerials otherwise i use dosch top people (and there are a couple others) which is photos of poeple taken from a higher angle.
                                          3d plants is fun but not very flexible so i would suggest a mix of 3d and photoshop vegetation, the 3d plants should offer a good example of how u would treat the photoshop plants light-wise. and personally i find it far more satisfying to have a good render with photoshoped vegetation rather than 3d. also 3d plants really cant fit into the high pace of a professional work flow.
                                          i draw personal inspiration from MIR (http://mir.no/) when it comes to enterage, i think they have it spot on, u can even see eddie murphy in a couple of renders.
                                          at the end of the day however it really is: "practice makes perfect" however tedious that might sound. ive had quite a bit and still feel im far from the MIR quality, because once you think you mastered one aspect of the rendering process (entourage) then u feel u need to work on another (lighting and environment)but then notice ur initial process could use more work. so progress is slow...
                                          Thom: im still active, i'll do another big gallery post soon, if i posted all the time it would become "Old Hat" nothing special.
                                          Focpt: in max u have object properties where u can specify invisible to camera, im not sure how vray for SU has advanced but the way i used to do it in SU was to place the tree billboard then on the face facing the camera apply a 100% transparent material so that its "invisible"
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                          • thomthomT
                                            Sean! 🎉
                                            Good to see you again!
                                            • 1 / 2
