    [Plugin] CADup
    64 Posts 28 Posters 90.3k Views 28 Watching
      barsaglini
      every time, I tried to use the plugin in houses that had already modeled, the sketchup closed =/
      small objects functioned normally
      πŸ˜„
        @barsaglini said:
        every time, I tried to use the plugin in houses that had already modeled, sketchup closed =/
        small objects functioned normally.
        πŸ˜„
        It is intended to CAD up components. A 'whole house' is going to be veeeery data intensive ???
        Perhaps the outer 'shell' will be OK but all of the internals that have to be inspected and discounted ????
        Even if 'hidden/off-layer!
        Export what you want to CAD up [select, right-click, save_as] and process that.
        There will be a new version out later today - see how that does... πŸ€“
        • W Offline
          watkins
          Morning TIG!
          Sound like you have a busy day!
          I am watching this space with interest as it has been suggested that postgrad students use SU for small design jobs rather than AutoCAD Inventor which is way over the top for most of their needs. Also, the free version od SU is, afterall, free. We have to watch our pennies these days, and even a student copy of Inventor is around Β£300.
          Regards,
          Bob
          • N Offline
            Nick2010
            Another Hit from Master Tig! Thank you so much!!!
              barsaglini
              get it!
              Great job, hope you can run stably!
              Tested on a cube, which made a hole in the left side, right side view of the hole he showed too;)
              Thank you.
                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=309485#p309485
                Container now made into a Component for easier export to SKP.
                Please read the notes with the download link... there have been changes...
                All SECTion and AXOnonmetric views have been added.
                Arrangement of the 'parts' has been adjusted and the use of the original selected object has be modified to minimize potential 'clashes'.
                Default file/layer name of '2CAD' now becomes 'SKAD'.
                Feedback please...............
                  Tip:-
                  The 6 SECTions are always cut at the center of the selected object's bounding-box.
                  If you want to make the sections in a different location then group the main component with between 1 and 6 guide-points [number depends on how many directions you want to slide the 'center'] - each suitably located to change the then combined bounding-box so that its center is now where you want the SECTion cuts to be placed [if your object us already a group you can add temporary guide-points to that]...
                    mado
                    Thanks, Tig
                    You can not even imagine the plugin is useful for furniture design.
                    • P Offline
                      philippequimper
                      When exporting to .DWG, all the lines are exported in the "0" layer without any sorting.. So I can't re-use efficiently this file in Autocad. Do I miss something?
                        Exporting a 2D file makes everything on one layer and ignores arcs etc.
                        Do it as 3D and it should export properly.
                        When in your CAD app set up 2D views of it... done πŸ˜„
                        • srxS Offline
                          srx
                          THANK YOU SO MUCH FOR THIS VERY USEFUL PLUGIN! πŸ˜„
                          www.saurus.rs
                            It's still at an early stage... next will be an interface to let you choose which views to export and several other options.. and perhaps auto-export to CAD format... Watch out for developments...
                              mizar
                              wonderful
                                Update:
                                Nothing new yet - I was somewhat bogged down by other issues this week... Designing door ironmongery and Revit stuff 🀒 et al... I'll try and get this restarted next week πŸ˜„
                                • gullfoG Offline
                                  gullfo
                                  a complete awesome plugin TIG! i did find one peculiar behavior with groups created with housebuilder - the xplode function seems to think the entities are deleted. here's the ruby console message:
                                  Error: #<TypeError: reference to deleted Group>
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in explode' C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in xplode'
                                  ...snip...numerous other lines...
                                  attached is the SU file which has the housebuilder group.
                                  test cadup with housebuilder script generated group
                                  Glenn
                                  http://www.runnel.com
                                    It's still 'work in progress' as I finish other paid stuff... I'll look and get back to you...
                                    • gullfoG Offline
                                      gullfo
                                      no worries. thanks!
                                      Glenn
                                        jim w
                                        Great Plugin !!!
                                        Thank you so much !!!
                                        The AXO's are great but I do a lot of "Isometeric Drawings" in CAD that have the base angles (x,y) at 30 degrees instead of the AXO's 45. Would it be possible somehow to get such an Iso at 30 degrees?
                                        Thanks again for you great work!!!
                                        Regards
                                          @jim w said:
                                          Great Plugin !!!
                                          Regards
                                          Iso's are MUCH harder to make than Axo's... that's why you don't get them πŸ˜‰
                                          I have a made a separate IsoAxo toolset to set a view to Iso or Axo [with model Z-scaling as needed] - search for that on the forums here...
                                          I have an upgrade in the pipeline [currently 'blocked'] but that's not on the list πŸ˜’
                                            lapx
                                            Hello Tig,
                                            Will this be similar to the old ADO autimatic drawings export of pages in dwg or image format. Do you recall this ruby script. It was very easy to use. I think Didier B was the original author. It as also very useful.
                                            Thanks,
                                            • 2 / 4
