    [Plugin] CADup
    64 Posts 28 Posters 97.0k Views 28 Watching
    • TIGT Online
      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=309485#p309485
      A Group OR an Instance can now be processed.
      Edges within any Groups/Instances nested within the Selected Object are now reproduced on appropriate layers.
      Edges that are hidden/smooth/soft in the Selected Object are now reproduced on the HIDN layer.
      Spacing of Views etc has been improved.
      Makes a trial version of a SECT-BOTTOM only - for feedback purposes...
      Makes a trial version of a AXO-SW only - for feedback purposes...SECT+AXO.PNG This is 'flat' example.
      Feedback please...
        dedmin
        (www.screencast.com)
        • TIGT Online
          Please retry... BUT this time move the component/group in question so that it is well out of the same space as the CADup versions... i.e. NOT near the origin... I suspect that there's 'interference' between the original and the copy...
          I can perhaps make this a v8 only app and hide the rest of the model...
          The idea is you have an instance off to one side and then it makes the 2d parts...
          Because it uses raytests and project_to_plane etc it can get confused...
          This is still in beta - thanks for the report...
            barsaglini
            every time, I tried to use the plugin in houses that had already modeled, the sketchup closed =/
            small objects functioned normally
            ๐Ÿ˜„
            • TIGT Online
              @barsaglini said:
              every time, I tried to use the plugin in houses that had already modeled, sketchup closed =/
              small objects functioned normally.
              ๐Ÿ˜„
              It is intended to CAD up components. A 'whole house' is going to be veeeery data intensive ???
              Perhaps the outer 'shell' will be OK but all of the internals that have to be inspected and discounted ????
              Even if 'hidden/off-layer!
              Export what you want to CAD up [select, right-click, save_as] and process that.
              There will be a new version out later today - see how that does... ๐Ÿค“
              • W Offline
                watkins
                Morning TIG!
                Sound like you have a busy day!
                I am watching this space with interest as it has been suggested that postgrad students use SU for small design jobs rather than AutoCAD Inventor which is way over the top for most of their needs. Also, the free version od SU is, afterall, free. We have to watch our pennies these days, and even a student copy of Inventor is around ยฃ300.
                Regards,
                Bob
                • N Offline
                  Nick2010
                  Another Hit from Master Tig! Thank you so much!!!
                    barsaglini
                    get it!
                    Great job, hope you can run stably!
                    Tested on a cube, which made a hole in the left side, right side view of the hole he showed too;)
                    Thank you.
                    • TIGT Online
                      Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=309485#p309485
                      Container now made into a Component for easier export to SKP.
                      Please read the notes with the download link... there have been changes...
                      All SECTion and AXOnonmetric views have been added.
                      Arrangement of the 'parts' has been adjusted and the use of the original selected object has be modified to minimize potential 'clashes'.
                      Default file/layer name of '2CAD' now becomes 'SKAD'.
                      Feedback please...............
                      • TIGT Online
                        Tip:-
                        The 6 SECTions are always cut at the center of the selected object's bounding-box.
                        If you want to make the sections in a different location then group the main component with between 1 and 6 guide-points [number depends on how many directions you want to slide the 'center'] - each suitably located to change the then combined bounding-box so that its center is now where you want the SECTion cuts to be placed [if your object us already a group you can add temporary guide-points to that]...
                          mado
                          Thanks, Tig
                          You can not even imagine the plugin is useful for furniture design.
                            philippequimper
                            When exporting to .DWG, all the lines are exported in the "0" layer without any sorting.. So I can't re-use efficiently this file in Autocad. Do I miss something?
                            • TIGT Online
                              Exporting a 2D file makes everything on one layer and ignores arcs etc.
                              Do it as 3D and it should export properly.
                              When in your CAD app set up 2D views of it... done ๐Ÿ˜„
                              • srxS Offline
                                srx
                                THANK YOU SO MUCH FOR THIS VERY USEFUL PLUGIN! ๐Ÿ˜„
                                www.saurus.rs
                                • TIGT Online
                                  It's still at an early stage... next will be an interface to let you choose which views to export and several other options.. and perhaps auto-export to CAD format... Watch out for developments...
                                    mizar
                                    wonderful
                                    • TIGT Online
                                      Update:
                                      Nothing new yet - I was somewhat bogged down by other issues this week... Designing door ironmongery and Revit stuff ๐Ÿคข et al... I'll try and get this restarted next week ๐Ÿ˜„
                                      • gullfoG Offline
                                        gullfo
                                        a complete awesome plugin TIG! i did find one peculiar behavior with groups created with housebuilder - the xplode function seems to think the entities are deleted. here's the ruby console message:
                                        Error: #<TypeError: reference to deleted Group>
                                        C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in explode' C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in xplode'
                                        ...snip...numerous other lines...
                                        attached is the SU file which has the housebuilder group.
                                        test cadup with housebuilder script generated group
                                        Glenn
                                        http://www.runnel.com
                                        • TIGT Online
                                          It's still 'work in progress' as I finish other paid stuff... I'll look and get back to you...
                                          • gullfoG Offline
                                            gullfo
                                            no worries. thanks!
                                            Glenn
                                            • 2 / 4
