    Tricky Twist
    28 Posts 13 Posters 4.5k Views 13 Watching
    • J
      JicJac
      I'm a noob, so if I have posted this in the wrong section or stepped on my toes in some other way, I apologize in advance of the flames.
      That said, I've been asked to create this object in SketchUp....
      http://www.3d-documents.com/images/01.jpg
      Is this possible?
      If it's a big deal or a complex solution, I can merely draw in in 2D (Corel Designer X5), faking the twist.
      Thanks,
      JJ
      • J
        Jim
        Hi JicJac, here's one way...
        http://i.min.us/je3lzm.png
        twisty.skp
          What's in the bottom right corner Jim?
          Nice tutorial too πŸ‘
          • J
            JicJac
            Jim,
            Thanks, that's one way to skin a cat.
            After I posted the challenge, I was thinking there might be a plugin for such things.
            Thanks again,
            JJ
            • soloS
              solo
              Fredoscale, pretty simple to use.
              http://img213.imageshack.us/img213/4135/capture46.gif
              http://www.solos-art.com
              • J
                JicJac
                Wow!
                *checks out Fredoscale....
                *begins plugin download
                From a quick glance at your presentation (graphic), it looks like Fredoscale uses the concept presented by Jim and automates it (the step-by-step process).
                I believe you have offered the ultimate solution.
                My hat is off,
                JJ
                • ely862meE
                  ely862me
                  Hmm..didn't even knew that Fredo's scale has that ability..
                  Anyway,the transition between the twist and the straight bar it's a bit odd.
                  With a bit more work u can achieve this result.With some arcs and Curviloft it came out pretty well.
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                  • J
                    JicJac
                    Amazing. Perfecto. It's a lot for me (noob/novice) to grasp. Now I have two plugins to learn. Will the learning never end?
                    Thank to all,
                    JJ
                    • ely862meE
                      ely862me
                      Learning never ends.
                      Twisted metall stripe by EliseiDesign.skp
                      • J
                        JicJac
                        Ah! Very clever. This looks like the type of solution I would come up with during my trial and error process. I understand (thanks to the great instructional presentation you prepared) the concept. When I have time, I'll give this a solution a try and let you know how it goes.
                        JJ
                        • HumpmetwiceH
                          Humpmetwice
                          Here is my attempt I tried the same technique as Solo but looks like his came out a lot better!
                          I was wondering Solo did you twist it all at once or did you do it in segments because I tried doing it all at once and didn't look right.Tricky Twist.png
                          Tricky Twist.skp
                          • J
                            JicJac
                            Are the plugins exclusive to MAC? ~ I'm running a PC.
                            I "think" I followed the instructions.....
                            http://www.3d-documents.com/images/Plugins.png
                            but I get this error message:
                            Error Loading File ZLoader__
                            no such file to load -- LibFredo6.rb
                            Error Loading File ZLoader__FredoScale.rb
                            It looks to me like a "Lib" file is needed?
                            I don't expect anyone to spend their time and talent troubleshooting for me. I suppose there is another forum section for these matters. But if I can help someone else down the line by pointing out a problem I'm experiencing, it's a good thing.
                            JJ
                            BTW, Thanks humpmetwice for your elegant contribution. I think this was a fun exercise for all.
                            • jeff hammondJ
                              jeff hammond
                              ha.. no. that almost never happens.
                              you're missing the libFredo files.. get them here:
                              404 Not Found
                              (forums.sketchucation.com)
                              dotdotdot
                              • J
                                JicJac
                                404 Not Found
                                Woot! Thanks Jeff. I have the Scale and Round Corner plugins now working.
                                I'll get the hang of it yet.
                                Thanks for helping me solve this issue,
                                JJ
                                • fuzzionF
                                  fuzzion
                                  Industrial design without Fredoscale is like trying to ride a bike
                                  without the wheels πŸ˜›
                                  "Only the dead have seen the end of war" - Plato
                                  • ArcA
                                    Arc
                                    You can use Curviloft plugin make this directly.
                                    • jarynzlesaJ
                                      jarynzlesa
                                      Nice work boys πŸ‘ .
                                      One question. Is any chance to make a radius on the edges?
                                      http://www.vizualizaceschodiste.mypage.cz/
                                      • fuzzionF
                                        fuzzion
                                        If you mean something like a rounded edge,chamber etc......use round corner plugin. You could also use the follow me
                                        tool but get ready to kick a dustbin whilst banging your head against a wall πŸ˜›
                                        • ely862meE
                                          ely862me
                                          well done ..very nice .. very fast
                                          Learning never ends!!
                                          • J
                                            JicJac
                                            Fuzzion,
                                            I believe ShetchUp is currently primarily used for architectural projects. I can certainly see where it's a big plus for industrial designers. The styles must come in real handy for you. There are probably 100 architects for every 1 industrial designers. I am a technical illustrator specializing in patent drawings. I only use SketchUp in about 2% of my projects. I expect it to climb to around 6-8%. I also use other products such as Corel Designer X5, QuadriSpace, SolidWorks, Adobe Illustrator, etc. The more "mechanical" features (plugins and functions) available in SketchUp, the more illustrators and industrial designers will be attracted. These opinions (and knee-jerk statistics) are my own guestimations.
                                            JJ
                                            • 1 / 2
