    How to make screen to shrink
    7 Posts 5 Posters 873 Views 5 Watching
    • jarynzlesaJ
      jarynzlesa
      Hi, I couldn't find how to shrink the screen visible area for rendering (as attached picture and *.skp).
      Thank you in advance jarynzlesa.
      screen_shrink.skp
      http://www.vizualizaceschodiste.mypage.cz/
      • daleD
        dale
        jarynzlesa
        I think that what you are trying to do is manipulate the aspect ratio.
        I believe this program called "Sizer" has been talked about (if I remember Gaieus recommended it)
        Have a look and see if this is what you need. http://www.brianapps.net/sizer/
        Cheers
          Isn't this possible thru TwiLight? Even the demo version? And Thea?
          • GaieusG
            Sizer is an excellent tool however it (re)sizes the whole SU Window and if you are not organized for this, it will clutter your toolbars.
            @jarynzlesa: would that size be an exact square? In which case you could use CubicPanoOut plugin to create 6 scenes of a cube for you (originally to export to a QTVR but eventually only one scene can also be used).
            • thomthomT
              You can also use V-Ray Toys (VfSU not required)
              • jarynzlesaJ
                jarynzlesa
                to dale: sizer is useful app but not this time, but thank you.
                to Gaieus: CubicPanoOut is interesting plugin, maybe i'll use it. thank you.
                to thomthom: can't find the V-Ray Toys plugin. Can you post a link. thank you.
                • thomthomT
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=15491&p=119728#p119728
