    How to make screen to shrink
    7 Posts 5 Posters 659 Views 5 Watching
    • jarynzlesaJ Offline
      jarynzlesa
      Hi, I couldn't find how to shrink the screen visible area for rendering (as attached picture and *.skp).
      Thank you in advance jarynzlesa.
      screen_shrink.skp
      http://www.vizualizaceschodiste.mypage.cz/
      • daleD Offline
        dale
        jarynzlesa
        I think that what you are trying to do is manipulate the aspect ratio.
        I believe this program called "Sizer" has been talked about (if I remember Gaieus recommended it)
        Have a look and see if this is what you need. http://www.brianapps.net/sizer/
        Cheers
          Isn't this possible thru TwiLight? Even the demo version? And Thea?
            Sizer is an excellent tool however it (re)sizes the whole SU Window and if you are not organized for this, it will clutter your toolbars.
            @jarynzlesa: would that size be an exact square? In which case you could use CubicPanoOut plugin to create 6 scenes of a cube for you (originally to export to a QTVR but eventually only one scene can also be used).
              You can also use V-Ray Toys (VfSU not required)
                jarynzlesa
                to dale: sizer is useful app but not this time, but thank you.
                to Gaieus: CubicPanoOut is interesting plugin, maybe i'll use it. thank you.
                to thomthom: can't find the V-Ray Toys plugin. Can you post a link. thank you.
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=15491&p=119728#p119728
