    TUT: Creating and Hatching in LayOut
    layout
    14 Posts 9 Posters 10.1k Views 9 Watching
    • RichardR Offline
      Richard
      From a PM to explain how to create and use hatch patterns in LO I thought I would share this simple process.
      I’ll example as a straight square tile hatch.
      CREATING HATCH (SEE HATCH.LAYOUT ATTACHED)
      1. Open a new LayOut document – Set page size to 200mm x 200mm / no margins / set grid 10mm / grid snap on / object snap off
      2. Using the line tool draw a line (1px wide) down one side and copy across each grid interval,
      3. Now turn snap to objects on, select all and rotate + crtl to copy rotate through 90deg,
        4.Export image as PNG say 500 x 500 pixels to keep it clean, note the larger the image the more LO will struggle when this is imported back in.
      USING HATCH (SEE IMAGE BELOW - HATCH USE)
      1. Open you working doc (the one you want to apply hatch to) drag and drop the PNG hatch image in,
      2. Place it where you wish to hatch and scale appropriately, and push it backward so it is behind the rest of the work,
      3. Now draw a line around the perimeter of the area you want hatched (I will assume this is less than the size of the hatch map – more later) and ensure this perimeter closes,
      4. Select both this traced perimeter and the hatch map, right click on then and from the context menu select “create clipping mask” – DONE!!!
      AREAS TO BE FILLED LARGER THAN THE HATCH MAP
      1. DO NOT try to duplicate the hatch map multiple times and then clip with one perimeter clip map! This will work first time yes BUT if you try to edit it later well ALL SHIT will break loose!
      2. To fill areas larger than the map, break the area up with multiple copies of the map and multiple clipping masks!!
      NOTE
      1. If you want a border around the hatched area simply select the clipped item and assign a stroke,
      2. If you have used multiple maps and clips and want the whole area to have a border select all clipped items, turn off and stroke and then trace around the whole perimeter, assign a stroke with no fill. These can then all be grouped – again DO NOT try to clip multiple copies of the map – you have been warned!
      CREATING A SCRAPBOOK LIBRARY OF HATCHING
      1. Open a new LO doc,
      2. Drag in all your hatch patterns and arrange as suits,
      3. Save doc as scrapbook – name file as wished!
      HOPE THIS HELPS!
      Resultant Hatch Pattern as descibed
      Hatch Use
      Hatch.Layout doc
      Hatch Use.layout doc
      BUILTBRAND.COM.AU
      • O Offline
        otb designworks
        Thanks Richard! This tutorial is excellent and much appreciated.
        Cheers, Chuck
        OTB Designworks is on Youtube
        • utilerU Offline
          utiler
          Me too, Richard. nice work around...! 👍
          Just Curious...
          • RichardR Offline
            Richard
            You welcome mate! The beauty of LO is it produces GREAT clean exports in both image formats and PDF so it's own exports make for very suitable content when bought back in!
            Did I say I love layout!
            BUILTBRAND.COM.AU
            • O Offline
              otb designworks
              I am a big fan of LO as well; I am glad that Google has continued development.
              Cheers, Chuck
              • RichardR Offline
                Richard
                Mate if many or even a few of the many requests that I know Andrew and myself have been pushing for through beta as additional functions are ever included Layout will become a serious app. Mind you I think the Googies have their own plans and IMHO they are pretty cluey guys and gals - so although we put up ideas they tend to run with some pretty funky ways to incorporate such functionality.
                For this reason I certain future builds will hold some VERY cool features!
                BUILTBRAND.COM.AU
                • utilerU Offline
                  utiler
                  @richard said:
                  Googies
                  Sounds like something that 'hatches' from your nose.....
                  Just Curious...
                    Googies are eggs here 😒
                    • utilerU Offline
                      utiler
                      same here, Rich; just depends how you say it.
                      Pronouncing double 'O' as in 'Good' gives you eggs.
                      Pronouncing double 'O' as in 'Google' gives you; well, nose stuff.
                      Just Curious...
                      • EdsonE Offline
                        Edson
                        thanks, richard! much appreciated. 👍
                        http://www.mahfuz.arq.br
                        • ladcweiL Offline
                          ladcwei
                          If we can fill sections of su model easily,that's must be a nice day.Sections are always complex,so we cann't draw alone them with pencil tool in LO.Hope that day coming soon......
                          • kaluK Offline
                            kalu
                            Excellent work Richard, thank you for your work.
                            Kalu.
                            PS. I will put my hands on it!
                            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                              alexdi
                              Спасибо Richard ! 👍
                              • P Offline
                                pedrinalex
                                Thank you Richard:
                                regards
                                Pedro
                                MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
