    [Plugin] Compo Spray 1.4.2 Updated
    271 Posts 89 Posters 326.0k Views 89 Watching
    • K Offline
      keithswd
      Does anyone know how to get this plugin working on a Mac install of SU2014? I get this error after installation:
      Error: #<SyntaxError: /users/keithpocock/library/application support/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:511: Invalid break
      /users/keithpocock/library/application support/sketchup 2014/sketchup/plugins/compospray/compoutils.rbs:520: Invalid break>
      Error Loading File compoSprayToolbar.rb
      Error: #<NoMethodError: undefined method compSpray_env' for main:Object> /Users/keithpocock/Library/Application Support/SketchUp 2014/SketchUp/Plugins/compoSprayToolbar.rb:7:in <top (required)>'
      • OxerO Offline
        Oxer
        On Mac & SU2014 you have to place the compoSprayToolbar.rb file and ComproSpray folder is this path:
        /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools
        Go to Applications folder select SketchUp app and right click Show package content
        http://www.oxervision.blogspot.com/
        • K Offline
          keithswd
          Thanks Oxer. I have just tried putting the file & folder as you suggest but still get the error. I have double checked that there is no longer a copy in either user Application Support../Sketchup subfolders, or in the system support folder, but up pops the error when I start up.
          The error has changed to the updated path for the script, so maybe something else is wrong:
          Error: #<SyntaxError: /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:511: Invalid break
          /applications/sketchup 2014/sketchup.app/contents/resources/content/tools/compospray/compoutils.rbs:520: Invalid break>
          Error: #<NoMethodError: undefined method compSpray_env' for main:Object> /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/compoSprayToolbar.rb:7:in <top (required)>'
          • soloS Offline
            solo
            So, any solution? I tried downloading it with the SCF plugin store but that did not work well, in fact it installs but nothing, no tool bar not in plugin menu, anyone?
            http://www.solos-art.com
            • OxerO Offline
              Oxer
              KeithSWD and Solo, try with this version updated by MTriple, it works fine for me on Mac OS X & SU2014, remember the path on OS X:
              CompoSpray
              • K Offline
                keithswd
                Many thanks Oxer (and MTriple) this version is working for me too!
                Glad to have this very useful tool back in operation.
                  ruriglen
                  The file MTriple uploaded to dropbox is offline, does anyone else has it, that kindly could uploaded again for sharing? Thanks!
                  • P Offline
                    penumbra
                    I give up on this plugin. Does not work on 2013 even the Mtriple fix. It won't accept a second point on the shapes (circle, square you name it). The developer has gone MIA...
                    • BoxB Offline
                      It does work on 2013 and 2014 with some tweaks.
                      Make sure you have the properties set to what you need and remember it needs a surface to spray on.
                      As for the developer being MIA, Didier has never said he supports this free plugin in perpetuity.
                      • chonC Offline
                        chon
                        Hello,
                        no match for me with CS modified and given by Oxer few posts above. I've tried to install the plugin in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools" (even then we should'nt use this folder as explained by TIG) and in "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins" but no success.
                        Cherry on the cake, i would like to install this plugin in an additional plugin folder using the Fredo6 tool (doesn't work in this folder neither of course).
                        Any one to help me ?
                        Thanks a lot !! πŸ˜‰
                        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                        • nghminh81N Offline
                          nghminh81
                          Thanks so much Oxer and MTriple. Your file works perfectly with my sketchup 2014!
                          To anyone who using Windows and still can't install it: Please extract files(ComposprayToolbar.rb and 1 folder Compospray) to "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools".
                          DON'T EXTRACT FILES TO "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
                          AND IF THEY WERE THERE (Because you tried to install it) Just DELETE.
                          • V Offline
                            valerostudio
                            Agreed. This works in 2014! Thanks!!!
                            • faBcnF Offline
                              faBcn
                              Hi there,
                              I do not see any window when clicking on Draw / Compo spray (SU 2013)...
                              Any idea ?
                              Thanx
                              • faBcnF Offline
                                faBcn
                                How I manage to make it work on SU 2013, here in Spain (with bloody accents everywhere...)
                                1- Copy/Paste CompoSpray folder + .rb in Plugins file as usual
                                2- Remove all .lingvo but CompoSprayUS.lingvo
                                and it works perfectly ! Nada mΓ‘s....
                                • chonC Offline
                                  chon
                                  Not for me in France ! 😞
                                  Still not working with my config...
                                  • V Offline
                                    valerostudio
                                    Broken again in 2015!!!
                                    • soloS Offline
                                      solo
                                      Confirmed
                                        Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
                                        I have already done of few of the easier ones... πŸ˜•
                                        I'll try and have a look at this one sometime this year !
                                          I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
                                          Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
                                          If you have messed on installing it in Tools etc please remove it manually and get/install the latest version...
                                          • OxerO Offline
                                            Oxer
                                            Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine. πŸ‘
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
