    More Characters
    Scheduled Pinned Locked Moved Organic Modelling
    71 Posts 25 Posters 42.3k Views 25 Watching
    • soloS
      solo
      Playing again, a quick Odie. I used SDS2, FFD and TOS.
      http://img713.imageshack.us/img713/4935/odiesumodel.png
      http://img441.imageshack.us/img441/439/odier.png
      And for those proxy junkies, here is the basic form.
      http://www.solos-art.com
      • L
        liam887
        Awesome! I cant wait for SDS2!!! πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
        VISIT MY ONLINE GALLERY
          Excellent Pete πŸ‘
          For the render/line overlay, what was the studio setup?
          • soloS
            solo
            I used Thea, posed in SU, exported the line image, opened same camera in Thea, added shadow catcher inifite plane, added HDRi image for reflection and white background (just a white .jpg I created in PS)
            Combines using 'multiply in PS...done.
              It was the White BG that i needed to know. Was the infinite plain a Diffused White? I really like that setup πŸ‘
              • soloS
                solo
                It's Odie, from Garfield. πŸ’š
                http://www.designsbyjoy.net/DesignerTag/Animation/GooGifs/odie.gif
                  Very cool Toon Dog β˜€
                  Does the new SDS2 has a Points/faces/polygons counter visible on the screen?
                  • michaliszissiouM
                    michaliszissiou
                    Nice dog.
                    Well done Pete,
                    Crits? Too many polys (but its OK here) much stretching on ears area, not the best for UVs.
                    • FrederikF
                      Frederik
                      @solo said:
                      ...exported the line image...
                      I've never figured how to do this...
                      Please enlighten us mortals...
                      If I export a line image, the background will not be transparent...
                      Cheers
                      Kim Frederik
                        I presume he sets the blend mode to overlay in Photoshop? That's what i do anyway 😳
                        • soloS
                          solo
                          @michal, Poly count is no issue, I dont mind high poly models, I use a studio renderer so that hurdle is overcome. I used FFD on ears so yes I stretched the mesh.
                          @Frederick and Rich, I use a white background when rendering so exporting SU lines with a white background actually helps, in PS I use 'multiply' for blend, makes lines pop better.
                          • jeff hammondJ
                            jeff hammond
                            if you export a tiff or png which support transparency then click 'transparent background' in the export options.
                            [though i'm thinking this may be a mac only feature?]
                            dotdotdot
                            • soloS
                              solo
                              Mac only... πŸ’š
                              See, there is a reason for owning a Mac. πŸ˜‰
                                What is it? You can it disappear into the BG
                                • FrederikF
                                  Frederik
                                  Cheers, Pete...
                                  Just thought you had a trick in your sleeve to export the lines with transparent background, but blending using 'multiply' works just fine... πŸ‘
                                  Edit: I knew I had seen somewhere that you're able to get transparent background on a Mac...
                                  Well, well... thomthom's Export 2d with Alpha can make similar png's for us depending on Windows... πŸ˜›
                                  Unfortunately only the background will be transparent and not objects (not even if you paint them in the same color as the bg)...
                                  Cheers
                                  Kim Frederik
                                  • michaliszissiouM
                                    michaliszissiou
                                    Multiply works fine, no need for transparent background.
                                    If you want transparent or semi transparent exports (lets say window glass etc) apply a strong color (pure magenta or green) then use it as mask in Ps. πŸ˜‰ A nice way for fake reflections in PP.
                                    • Chris FullmerC
                                      @solo said:
                                      Mac only... πŸ’š
                                      Actually, that is no longer true. I think since they re-built the SU render engine in 7.1, PC has been able to export transparent png's.
                                      All my Plugins I've written
                                      • FrederikF
                                        Frederik
                                        Please elaborate and post some screen shots, Chris...
                                        Cause I sure can't find this in the option menu...
                                        I've tried both tif and png - and I don't see any option for selecting transparent background...
                                        Cheers
                                        Kim Frederik
                                        • michaliszissiouM
                                          michaliszissiou
                                          Really Frederik, you don't need this much. You may need to mask some glass windows too, transparency doesn't help much there. Try to assign a pure green or magenta instead. Ps can do miracles this way. From a mac user anyway.
                                          • FrederikF
                                            Frederik
                                            I know, michalis...
                                            I can make incredible things in post pro with PS for Win... πŸ˜„
                                            I also know about the work arounds, but if I can avoid them, it would be great...
                                            Chris F. states that transparent background is possible with SU for Win since ver. 7.1 but I can't find how/where, hence my question to Chris to post some screen shots...
                                            Well, well... I don't want to hijack this thread... πŸ˜„
                                            Cheers
                                            Kim Frederik
                                            • 1 / 4
