    Edge color by layer
    30 Posts 6 Posters 6.8k Views 6 Watching
      danbig
      Hi all -
      Just confirming: there isn't a way to color edges by layer in sketchup, is there?
        Not that I can find. You could apply a colored material to the edges and set line color to By Material. Would that help?
        • wind-borneW Offline
          wind-borne
          404 Not Found
          (forums.sketchucation.com)
          choose layer and edge color
          "To read between the lines was easier than to follow the text."OSX 10.11.6
          %(#BF80BF)[SU 8 pro
            Very good. I forgot about that tool in that plugin set.
              Also, if you colour everything (not just edges but faces as well) by layer and set your edge styles "by material", SU will apply the layer colour to the edges, too.
                Csaba, so the combinetation of Edge color set to By Material and Layers set to Color by Layer will do it. Slick. I don't think I would have found that combination. Although I rarely use Color by Layer, it could come in handy. Thanks.
                  I also rarely use colour by layer although once I did (note that image entities will remain uncoloured by layer if you do not explode them):
                  YouTube - Some phases of a Roman archaeological site
                  [flash=500,400:150tkom7]http://www.youtube.com/v/bKsEpF1Neh0?fs=1&hl=en_US[/flash:150tkom7]
                    That's very interesting. Over what time period were all those different buildings constructed?
                      Beginning of 2nd century up to the second half of the 4th (AD of course). "Phase 8" (with the potato-shaped pits) is already end of / right after the Roman rule in the 5th century.
                        That seems like a lot of reconstruction in not so many years.
                          Don't forget wars... This is one of the most significant military provinces of Rome (actually, just a 40 km wide but couple of hundred km long frontier zone) which was under the biggest and most frequent pressure by barbarian raidings. Most of these buildings were completely destroyed and burnt to the ashes instead of just rebuilt due to some city planning reasons.
                            Interesting stuff. I would love to see it in person one day.
                              Here are some pics of the excavation (not too hi-res however). I have more (hi-res) but alas I cannot share as it was not my excavation. πŸ˜’
                                Uh....Where's "here"? πŸ˜‰
                                  Oops, sorry. Here:
                                  http://www.pecskep.hu/logic/pages/showdoc.php?id=299
                                  And some more/somewhat bigger (with my humble models/renders)
                                  πŸ˜’
                                  http://www.pecskep.hu/logic/pages/showdoc.php?id=729
                                    danbig
                                    Thank you, sir. I'm sure this isn't the first time you've shared this tip.
                                      If it isn't the first, I am sure glad I caught it this time. I immediately put it to use.
                                      http://farm6.static.flickr.com/5003/5263239453_ac180e8a2c_m.jpg
                                        I dunno guys. I just tried when the question arose...
                                        πŸ˜’
                                        • jgbJ Offline
                                          jgb
                                          Could you please point me to where I can learn to create an animation as depicted above? πŸ‘
                                          I will need to do one early next year on my Silver Dart model for an aviation museum both here in Toronto and Hamilton. It needs to be an AVI/MOV/MPG file to be put on a DVD for a continuous show. I want to show how the craft was constructed while doing a walk-around, then place the camera at the pilots eye for a look around through the twigs and wires.
                                          thanks.
                                          jgb
                                            I actually exported the animation in image sequences then made smaller animations which I used to put together into a bigger one together with stills and added transition between the animations.
                                            I can send you the whole animation project folder and you can see how it is put together in Windows Movie Maker 😳 (so it is rather low resolution, too)
                                            • 1 / 2
