    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Method for drawing an antiprism with equilateral sides
    35 Posts 7 Posters 5.2k Views 7 Watching
    • honoluludesktopH Offline
      honoluludesktop
      • jeff hammondJ Offline
        jeff hammond
        here's another solution that allows rotating without the mega-segment arc..
        antiprism.skp
        same file.. saved as su6
        dotdotdot
          jeff hammond
          PS :How many triangles must have the polyedra?
          On the first post there are 8 on "the plan"
          On the Xray Tig volume there are 7 ! ๐Ÿ˜ฎ
          i don't think it matters.. here's an example using octagons with one of them rotated 22.5 degrees then using the same exact method i used for the squares.. resulting in 16 equal sides. (i think the people trying it though are using the wiki example which has 7 sides.)
          edit -- lol. the wiki one, the one i drew, the one tig drew..etc have 8 sides hah ๐Ÿ˜ณ
          dotdotdot
            PS :How many triangles must have the polyhedron?
            On the Xray TIG volume there are 7 ! ๐Ÿ˜ฎ
            Won't the file lose some of its v7, and v8 features. Did v6 have "dynamic components", etc.?
            there are rarely dynamic component in "hard geometry" like in this post or exotic functions ๐Ÿ˜„
            In my Xray volume there are 8 triangles BUT the left-hand-most one is almost square to the camera ๐Ÿ˜’
            A very neat solution by Jeff BTW... ๐Ÿ˜„
              If you think about it... as you increase the number of sides for the top and bottom faces the nearer they approximate the circles and the smaller the sides of the equilateral triangles forming the side facets so the 'height' decreases until with thousands of sides the top and bottom are approaching coplanarity...
              The simplest form has equilateral triangular faces, the next squares and so on.
              there are always twice as many sides as the edges to the faces: so the triangle solution has 3x2=6 sides, the square 4x2=8 sides and so on...
                Ahhhh! I was victim of the perspective's law ๐Ÿ˜ณ ๐Ÿ’š
                  Thx to Jeff for the "SU6 work" ๐Ÿ˜‰
                  (you use unity of the old 20 century ๐Ÿ˜„
                  And Chris Fullmer for his Component onto face ๐Ÿ˜„
                  Now I can see all 8 triangles! ๐Ÿ’š
                  The TIG's View was not good oriented! ๐Ÿ˜†
                    To simplify things I have made a 'quick' Plugin - it's here http://forums.sketchucation.com/viewtopic.php?p=287140#p287140
                    You just type into the Ruby Console:
                    antiprism 7,1200.mm
                    and it'll makes a 7 sided antiprism with sides 1200mm long, centered on the origin and grouped, named 'Antiprism[7x1200]'...
                    You have to have at least 3 sides and a side-length > 0; the length is taken as inches if you haven't given a units suffix like 1.m or 100.cm or 1000.mm etc.
                    The distance between faces changes with the number of sides as the maximum 'rake' on the side-triangle occurs at with 3 sides, and it proportionately decreases as the number of sides increases, until you approximate to a circle with a multi-sided polygon, and by then the side-triangles are almost vertical...
                      Else a very speedy method ๐Ÿ’š
                      Draw Square A 1m * 1m (on the plan)
                      Copy rotate Square A 45ยฐ = Square B (on the plan)
                      Move Up Square B 1m on Z
                      Draw the 8 segments between 8 vertices
                      Select these 8 segments (method as you want)
                      Scale on Z (Blue Scale oposite point) 0.840892091m (magical number) ๐Ÿ˜†
                      Move down Square B vertical snaped a triangle vertice
                      That's all ๐Ÿ’š
                      And then you can resize at any size for any cubic antiprism with the Tape Mesure tool ๐Ÿ’š
                      And all that without plugin, that is a real performance for me ๐Ÿ˜†
                        sketchup_roolz
                          honoluludesktop
                          Else a very speedy method .............And all that without plugin, that is a real performance for me :lol:
                          Genius:-)
                            jeff hammond
                            frenchy, i think the challenge is to figure out a way to do it using only geometry/tricks available in sketchup. (ie- doing this in rhino for instance would be very easy)
                            that said, i think my method exposes a tolerance error in sketchup.. it shouldn't work but it does..
                            [edit, nevermind.. i just tried it with engineering/feet/.000001 precision and it does infact show the error..]
                            i couldn't figure out why i wasn't getting a ~ in front of my measurements because in my head, it should of been there..
                            -reason why there's an error: once you copy move the line up, make it perp to the hypotenuse, then rotate it /snap to the vert line, it doesn't end up being horizontal.. it's ever so slightly angled down.. i knew it was doing it but thought SU was thinking 'meh, close enough'..
                            but, after doing this exercise, i realize sketchup actually will say 'meh, close enough' when it comes to adding a ~ in front of certain measurements..
                            [edit]
                            the method i showed will give an equilateral triangle on one side but you'll see that it ever so slightly shifts the top square off center..
                            dotdotdot
                            • Jean LemireJ Offline
                              Jean Lemire
                              Hi Jeff, hi folks.
                              I noticed very small errors in the sides of the equilateral triangles. They are not all absolutely equal to 10 feet.
                              See you file with added dimensions.
                              antiprism_V6.skp
                                jeff hammond
                                hi Jean.
                                yeah, that's what i was talking about in the post just before yours.
                                i found the error too (and at first thought it was ok because sketchup wasn't giving me an approximate ~ measurement)
                                i came up with a way to do it in su only with no calculator but it's a bit drawn out and confusing.. i'll try another method when i get more time. (different than the hyper-segmented arc that tig showed -- which is probably the fastest/easiest)
                                but, i'm thinking you could come up with a clever method to accomplish it ๐Ÿ˜‰
                                dotdotdot
                                  @Jean ๐Ÿ˜‰
                                  That is writed v6 but it is in fact v8 so the suspense is total for me ๐Ÿ˜„
                                  @Jeff
                                  Maybe you must multiply scale by 10 000 then make the rotation for win some decimal?
                                  • 2 / 2
