    How to model a curvy wing tip
    7 Posts 4 Posters 663 Views 4 Watching
    • numbthumbN Offline
      numbthumb
      OK, so I must be missing something really obvious, but I just cannot wrap my head around this.
      I´ve decided to rebuild some of my airplane models, but I am having trouble understanding the right ( or the most convenient ) way of closing a wingtip 😳 it usually ends with a quite smooth & round cover, as shown in the image
      Or should I just stick to square wings?
      Comfortably numb...
        You can either use EEbyR or Curviloft. Attached is an example to run either plugin on...
        Numbthumb Skin.skp
        I didn't spend much time with the Trailing Edge as you asked on how to create a smooth end. I could be misunderstanding the question too? 😕
          Here's a screen-shot of a three step solution based on Rich's curves & my EEbyRails - took two minutes...Capture.PNG
            numbthumb
            Darn it, I should have stuck to balsa wood - I totally forgot about these plugins 😳
            I also assume that, depending on the airfoil shape, you can model the upper and the lower part separately, and then "glue" them together?
            Thanks for you replies, guys! Tutorials I have found usually involve some kind of mesh smoothing, but I don´t think that SDS would be a better solution.
            Thanks again!
            Comfortably numb...
              No problem. To improve the mesh you can increase the number of segments in the polylines. Curviloft does allow you to play with the mesh somewhat so that's a good choice.
                As i made this today a copy past is not a big deal 😄
                Extrude Edges Tools by Rail by TIG
                http://forums.sketchucation.com/download/file.php?id=58100
                  numbthumb
                  Thanks, Pilou!
                  Now it really gets me thinking about building a whole thing that way - something like this could be a good start 😄
                  Comfortably numb...
