๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
How to model a curvy wing tip
7 Posts 4 Posters 357 Views 4 Watching
  • N Offline
    numbthumb
    OK, so I must be missing something really obvious, but I just cannot wrap my head around this.
    Iยดve decided to rebuild some of my airplane models, but I am having trouble understanding the right ( or the most convenient ) way of closing a wingtip ๐Ÿ˜ณ it usually ends with a quite smooth & round cover, as shown in the image
    Or should I just stick to square wings?
    Comfortably numb...
    • R Online
      You can either use EEbyR or Curviloft. Attached is an example to run either plugin on...
      Numbthumb Skin.skp
      I didn't spend much time with the Trailing Edge as you asked on how to create a smooth end. I could be misunderstanding the question too? ๐Ÿ˜•
        Here's a screen-shot of a three step solution based on Rich's curves & my EEbyRails - took two minutes...Capture.PNG
        • N Offline
          numbthumb
          Darn it, I should have stuck to balsa wood - I totally forgot about these plugins ๐Ÿ˜ณ
          I also assume that, depending on the airfoil shape, you can model the upper and the lower part separately, and then "glue" them together?
          Thanks for you replies, guys! Tutorials I have found usually involve some kind of mesh smoothing, but I donยดt think that SDS would be a better solution.
          Thanks again!
          Comfortably numb...
          • R Online
            No problem. To improve the mesh you can increase the number of segments in the polylines. Curviloft does allow you to play with the mesh somewhat so that's a good choice.
              As i made this today a copy past is not a big deal ๐Ÿ˜„
              Extrude Edges Tools by Rail by TIG
              http://forums.sketchucation.com/download/file.php?id=58100
              • N Offline
                numbthumb
                Thanks, Pilou!
                Now it really gets me thinking about building a whole thing that way - something like this could be a good start ๐Ÿ˜„
                Comfortably numb...
