    Top 3 SU plugins
    80 Posts 40 Posters 18.4k Views 40 Watching
      tfdesign
      Cheers Dave 😄
      My book "Let's SketchUp!" Download from here
      • PixeroP Offline
        Pixero
        I dont know if my most used plugins are my favorites but anyway:
        Put on layer (I use it ALL the time to keep my file organised.)
        Weld (I've edited it so I have it under the right click menu)
        Joint pushpull (Could also be Extrude edge by vector)
        • gullfoG Offline
          gullfo
          my top 3:
          House Builder (imperial and metric)
          Extrusion Tools
          Weld
          Glenn
          http://www.runnel.com
            JuanV.Soler
            2D Tools
            Work Plane
            Colour Edge
            field of use : architecture
              tfdesign
              Wow Pilou! That's beautiful!
              • EscapeArtistE Offline
                EscapeArtist
                Based on use:
                Weld
                Remove unused edges
                BZ spline (all)
                Based on coolest/usefulness (IMO)
                SD&S
                Curviloft
                JPP
                All of the above make SU easier and better to use.
                  blajnov
                  kate-art, it's not all... 😲 😒 ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                  • mitcorbM Offline
                    mitcorb
                    I already gave you three--for this week. I also like to see how well I can do some operations from scratch. However, I don't think Weld has a native substitute.
                      The 3 more fun 😎 (for me 😒
                      Grow by Tig perfect for iteration volumes with multiple size, Move, rotate
                      Protrude by Jim Foltz funny automatic exotic generations
                      Random Painter by Chris Fullmer for some joyous variations of colors
                      3 in the same time 😄
                      • K Offline
                        kate-art
                        Great feedback guys - thanks. I find it interesting how everyone likes something different. This short thread has generated a list of 30+ plugins!
                        Shaderlight delivers interactive, photorealistic rendering to Google SketchUp. Download it for FREE at http://www.shaderlight.com
                          tfdesign
                          Brilliant! Then I too will also go with these as well 😄
                            DIEGO-RODRIGUEZ
                            extrusion line
                            mirror
                            joint push pull
                            • EdsonE Offline
                              Edson
                              mirror
                              podium
                              1001bit tools
                              http://www.mahfuz.arq.br
                              • H Offline
                                haynesc
                                I couldnt decide 3 so anyof the below :
                                PurgeAll
                                Make Faces
                                Frontface
                                Weld
                                Default Layer Gemometry
                                SceneExporter Pro
                                Extrude Tools
                                Curviloft
                                Curvishear
                                CD STANDARD & CD TOOLSET Toolbars
                                Zorro
                                Move to Orgin
                                Remove Materials
                                joint push pull
                                1001 tools
                                • daleD Offline
                                  dale
                                  TOS
                                  1001 bit Tools
                                  Joint Pushpull.....For work
                                  The one I use when I am playing SDS, Fur
                                  • Chris FullmerC Offline
                                    I totally agree on this one. It is invaluable to me. Move all geometry to layer 0 while keeping all groups, images, components on the layer they were on. Absolute must for clean modeling habits.
                                    All my Plugins I've written
                                    • arquitectomaracuchoA Offline
                                      arquitectomaracucho
                                      Curviloft 😍
                                      1001 bit Tools
                                      joint push pull
                                      tools on surface
                                      • EdsonE Offline
                                        Edson
                                        I gather you mean to say "move all loose geometry, that is, not grouped or turned into a component".
                                          tfdesign
                                          Chris, why is that so important/ invaluable?
                                            Edson, the plugin Chris refers to does move all geometry whether it is loose or in a component/group to the Default layer as he wrote. It is very handy for cleaning up models. I end up using it once in awhile on models others send me but I have adopted a practice in which I never set any layer other than the default as active.
                                            • 2 / 4
