    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 474.8k Views 75 Watching
    • G Offline
      gr8fzy1
      I can't even seem to get the plugin to show up for me! I have both the ruby and the TT Lib folder in my plugins folder, but when I start Sketchup it won't show in the plugins pull down menu. (I'm using Sketchup 8 Pro. My OS is Vista Basic)
      http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapproblem.jpg
      http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapproblem2.jpg
      • david_hD Offline
        david_h
        I had the same problem.
        Look in the DRAW menu. "Mesh to Bitmap"
          If it's not under the 'Draw' menu look here - you probably have limited permissions to Plugins and haven't really installed them...
          Look in the linked 'Compatibility Files' folder and move them across - it's Vista being over cautious again!!
            It is worth having a look at the description of the plugin, espesially whrn you have problems.
            • G Offline
              gr8fzy1
              I clicked on compatibility files, and these are the only ones listed. TT Bitmap to Mesh isn't included.
              http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapProblem3.jpg
              I just looked in the DRAW menu, and found something called "Mesh from Heightmap"
              Is this something included in sketchup, or is it the same as "Mesh to Bitmap"? I've never used the Draw pulldown before so I don't know what's usually there.
              Clicking on "Mesh from Heightmap" seems to do the same thing as the TT ruby, right down to the red scaling box and asking me to input a depth measurement. So I THINK it might be the same thing...
              http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapProblem4.jpg
              http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapProblem5.jpg
              http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapProblem6.jpg
              http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapProblem7.jpg
              It's megaman!
              http://i44.photobucket.com/albums/f42/gr8fzy1/TTBitmapProblem8.jpg
                Did you read the first post of this thread? It instructs the user to access this 'mesh from height map' in the 'draw' menu.
                • G Offline
                  gr8fzy1
                  I did, but since I don't have my own internet connection I can only read so many pages in the 60 minutes of internet time I get at the public library. And combine that with having to fill out online applications for work and checking my email, I last read page one about 2 weeks ago. Please forgive me...
                    No need to read all the other posts, but the first post - the one that describes the plugin.
                    • G Offline
                      gr8fzy1
                      But I also read all the other posts in case problems are noticed and discussed, that way I won't be calling attention to a problem that has already been fixed, or at least see if anyone else is having the same problem I'm having. Which I failed on both counts. Oh well, At least I know my problem was a non issue. Thanks.
                      • G Offline
                        gidominik
                        Hi Thomthom, Just wondering, I installed the plugin to the plugin folder, but it didn't show the cursor, or when I right click the bitmap it didn't show the selection of bitmap to mesh.Any suggestion?? 😳
                          Is the .rb file placed directly in the plugins folder?
                          Do you have TT_Lib2 installed?
                          Are you right clicking an Image entity?
                          • G Offline
                            gidominik
                            Yes Sir, everything was in placed
                              Doy
                              Can you post a screen-shot of the folder[s] please...
                              • G Offline
                                gidominik
                                @tig said:
                                Doy
                                Hi Tig,
                                Thanks. see the screen shot.
                                  That's your problem right there. That TT_Lib2 - 2.6.0 should contain a TT_Lib2 folder, and that is the folder which should be in the plugins folder. Note the footprint which is described for both TT_Lib and Bitmap to Mesh.
                                  ...though you should have gotten an error message when you loaded SketchUp when Bitmap to Mesh failed to load TT_Lib2. ...unless that also is wrapped in a folder...?
                                    Ah! I see it right there, a folder named "QuadFaceTools - (0.4.1)". When downloading the plugins, copy the content of the zip files to the plugins folder, do not let the extracter wrap it in another folder.
                                    • G Offline
                                      gidominik
                                      Hi Thom, Problem solved...Thanks so much, πŸ‘ πŸ‘ πŸ‘ β˜€ one of my favorite plugin....
                                      • G Offline
                                        gidominik
                                        I got it right this time... πŸ‘ πŸ‘ πŸ‘ πŸ‘ 😎 Thank you
                                        • Mistro11M Offline
                                          Mistro11
                                          Hi ThomThom! Another great plugin I discovered by you! I been flirting with Blender, Terragen 2, and shopping around for terrain generating solutions for a couple months now. I was planning on using Artisan and your useful Vertex Tools (perfect for fine tuning natural shapes I imagine) to sculpt terrain and do a composite in other software. I will still use those plugins but this just cut all kinds of time down for that process. I have terrains that have specific landmarks and features so knowing I can work from greyscale images in sketchup is blowing my mind right now. Thank you again.
                                          Just one concern before really diving in... When I go to the draw menu I only see Mesh from Heightmap option and not the added BMP to Mesh. I just downloaded the version on page one. Should I be seeing the 2 options you show?
                                          As you can see it's different from example on page 1
                                          I put the ruby file in the plugins folder and I'm on Win XP. And is there any more documentation for this?
                                          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                          Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                            πŸ˜‰
                                            Beware that you get a very dense mesh! Keep the bitmaps small! Very small!
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 9 / 14
