    Layer color by ruby-code?
    16 Posts 3 Posters 1.6k Views 3 Watching
    • A
      Andreas
      Is it possible to set the layer color by ruby-code?
      With best regards from Germany
      Andreas
      • thomthomT
        Annoyingly - no. It's one of the missing API methods. We can't get/set the layer material, nor can we set material name, erase materials or layers. 😞
        • A
          Andreas
          I tried it with "layer-color=.rb"
            layer = model.layers.add "my_layer"
            layer.color = [255,255,255]
          But there is the following error:
          "undefined method `page_behavior=' for nil:NilClass"
          Do you have an idea why the error occurs?
          Andreas
          • TIGT
            There is no built-in API layer.color=
            BUT see here for my stop-gap new method... http://forums.sketchucation.com/viewtopic.php?p=177016#p177016
            with that loaded your example layer.color= [255,255,255] should work...
            • thomthomT
              See his last post...
              • TIGT
                It works OK for me... πŸ˜•
                • thomthomT
                  would help if we got the whole error - with the line number and traceback
                  • A
                    Andreas
                    I tried that. I copied "layer-color=.rb" to plugins folder.
                    And than there was the error when I start my code.
                    What is the mistake I made?
                    Andreas
                    • thomthomT
                      what is the full error?
                      line of error, and traceback?
                      • TIGT
                        Have you restarted SUp after installing the new code script ?
                        • A
                          Andreas
                          Yes
                          Andreas
                          • A
                            Andreas
                            The file "test.rb" is in plugins folder.
                            ThatΒ΄s the whole code of test.rb
                              model = Sketchup.active_model
                              layer = model.layers.add "ABS_Grundriss_Wand2"
                            The following error message appears if Sketchup start:
                            %(#FF0000)[Fehler beim Laden der Datei test.rb
                            undefined method `page_behavior=' for nil:NilClass]
                            That error appears in context with "layer-color=.rb" which is in
                            plugins folder too. If I remove "layer-color=.rb" from plugins folder
                            there is the following error message:
                            undefined method `color=' for #Sketchup::Layer:0x6dfe1ec]
                            That error I understand.
                            Andreas
                            • thomthomT
                              But there should be a traceback.
                              If you have a file like this:
                              def test_me
                                x == y
                              and then call that method you should get this error:
                              Error: #<NameError: undefined local variable or methodx' for main:Object>
                              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/testme.rb:2
                              (eval):2537`
                              Notice it includes the filename and line number after reporting the error. Do you not get that kind of error?
                              • thomthomT
                                I see an issue with this method:
                                It has multiple .start_operation and commit_operation inside the code flow - which will interfere with any start_operation you started yourself - since SU doesn't handle nested start_operations:
                                ` model.start_operation
                                layer.color = 'red' # this breaks the undo stack
                                model.commit_operation`
                                Though, it is not related to the error you got.
                                • A
                                  Andreas
                                  > def test_me
                                  >   x == y
                                  > end
                                  (eval):2537`
                                  The first way I test was run automatically at the Sketchup start.
                                  There was only the error message I posted.
                                  Andreas
                                  • A
                                    Andreas
                                    Sorry, I donΒ΄t understand that.
                                    I tried now that:
                                    def layer_color
                                      layer = model.layers.add "Test_Layer"
                                    if( not file_loaded?("test.rb") )
                                      plugins_menu = UI.menu("Plugins")
                                    	plugins_menu.add_item("LayerColor") {layer_color}
                                    file_loaded("test.rb")
                                    That works without error - but the new layer has the color 102,68,0
                                    and not 255,255,255!!!???
                                    I test that:
                                    def layer_color
                                      layer.color = "Blue"
                                    The same result like before - Color 102,68,0 instead of blue
                                    Than I test that:
                                    def layer_color
                                      my_mat = materials.add "Ahorn"
                                      my_mat.texture = "O;\\Sketchup\\Mat\\Ahorn.jpg"
                                      layer.color = my_mat
                                    There was no error but also no layer!!
                                    Andreas
