    Layer color by ruby-code?
    16 Posts 3 Posters 1.6k Views 3 Watching
      It works OK for me... 😕
        would help if we got the whole error - with the line number and traceback
          Andreas
          @tig said:
          There is no built-in API layer.color=
          BUT see here for my stop-gap new method... http://forums.sketchucation.com/viewtopic.php?p=177016#p177016
          with that loaded your example layer.color= [255,255,255] should work...
          I tried that. I copied "layer-color=.rb" to plugins folder.
          And than there was the error when I start my code.
          What is the mistake I made?
          With best regards from Germany
          Andreas
            what is the full error?
            line of error, and traceback?
              Have you restarted SUp after installing the new code script ?
                Andreas
                Yes
                Andreas
                  Andreas
                  The file "test.rb" is in plugins folder.
                  That´s the whole code of test.rb
                    model = Sketchup.active_model
                    layer = model.layers.add "ABS_Grundriss_Wand2"
                    layer.color = [255,255,255]
                  The following error message appears if Sketchup start:
                  %(#FF0000)[Fehler beim Laden der Datei test.rb
                  undefined method `page_behavior=' for nil:NilClass]
                  That error appears in context with "layer-color=.rb" which is in
                  plugins folder too. If I remove "layer-color=.rb" from plugins folder
                  there is the following error message:
                  undefined method `color=' for #Sketchup::Layer:0x6dfe1ec]
                  That error I understand.
                  Andreas
                    But there should be a traceback.
                    If you have a file like this:
                    def test_me
                      x == y
                    and then call that method you should get this error:
                    Error: #<NameError: undefined local variable or methodx' for main:Object>
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/testme.rb:2
                    (eval):2537`
                    Notice it includes the filename and line number after reporting the error. Do you not get that kind of error?
                      I see an issue with this method:
                      It has multiple .start_operation and commit_operation inside the code flow - which will interfere with any start_operation you started yourself - since SU doesn't handle nested start_operations:
                      ` model.start_operation
                      layer.color = 'red' # this breaks the undo stack
                      model.commit_operation`
                      Though, it is not related to the error you got.
                        Andreas
                        > def test_me
                        >   x == y
                        > end
                        (eval):2537`
                        The first way I test was run automatically at the Sketchup start.
                        There was only the error message I posted.
                        Andreas
                          Andreas
                          Sorry, I don´t understand that.
                          I tried now that:
                          def layer_color
                            layer = model.layers.add "Test_Layer"
                          if( not file_loaded?("test.rb") )
                            plugins_menu = UI.menu("Plugins")
                          	plugins_menu.add_item("LayerColor") {layer_color}
                          file_loaded("test.rb")
                          That works without error - but the new layer has the color 102,68,0
                          and not 255,255,255!!!???
                          I test that:
                          def layer_color
                            layer.color = "Blue"
                          The same result like before - Color 102,68,0 instead of blue
                          Than I test that:
                          def layer_color
                            my_mat = materials.add "Ahorn"
                            my_mat.texture = "O;\\Sketchup\\Mat\\Ahorn.jpg"
                            layer.color = my_mat
                          There was no error but also no layer!!
                          Andreas
