    Layer color by ruby-code?
    16 Posts 3 Posters 1.6k Views 3 Watching
      There is no built-in API layer.color=
      BUT see here for my stop-gap new method... http://forums.sketchucation.com/viewtopic.php?p=177016#p177016
      with that loaded your example layer.color= [255,255,255] should work...
        See his last post...
          It works OK for me... 😕
            would help if we got the whole error - with the line number and traceback
              Andreas
              I tried that. I copied "layer-color=.rb" to plugins folder.
              And than there was the error when I start my code.
              What is the mistake I made?
              With best regards from Germany
              Andreas
                what is the full error?
                line of error, and traceback?
                  Have you restarted SUp after installing the new code script ?
                    Andreas
                    Yes
                    Andreas
                      Andreas
                      The file "test.rb" is in plugins folder.
                      That´s the whole code of test.rb
                        model = Sketchup.active_model
                        layer = model.layers.add "ABS_Grundriss_Wand2"
                        layer.color = [255,255,255]
                      The following error message appears if Sketchup start:
                      %(#FF0000)[Fehler beim Laden der Datei test.rb
                      undefined method `page_behavior=' for nil:NilClass]
                      That error appears in context with "layer-color=.rb" which is in
                      plugins folder too. If I remove "layer-color=.rb" from plugins folder
                      there is the following error message:
                      undefined method `color=' for #Sketchup::Layer:0x6dfe1ec]
                      That error I understand.
                      Andreas
                        But there should be a traceback.
                        If you have a file like this:
                        def test_me
                          x == y
                        and then call that method you should get this error:
                        Error: #<NameError: undefined local variable or methodx' for main:Object>
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/testme.rb:2
                        (eval):2537`
                        Notice it includes the filename and line number after reporting the error. Do you not get that kind of error?
                          I see an issue with this method:
                          It has multiple .start_operation and commit_operation inside the code flow - which will interfere with any start_operation you started yourself - since SU doesn't handle nested start_operations:
                          ` model.start_operation
                          layer.color = 'red' # this breaks the undo stack
                          model.commit_operation`
                          Though, it is not related to the error you got.
                            Andreas
                            > def test_me
                            >   x == y
                            > end
                            (eval):2537`
                            The first way I test was run automatically at the Sketchup start.
                            There was only the error message I posted.
                            Andreas
                              Andreas
                              Sorry, I don´t understand that.
                              I tried now that:
                              def layer_color
                                layer = model.layers.add "Test_Layer"
                              if( not file_loaded?("test.rb") )
                                plugins_menu = UI.menu("Plugins")
                              	plugins_menu.add_item("LayerColor") {layer_color}
                              file_loaded("test.rb")
                              That works without error - but the new layer has the color 102,68,0
                              and not 255,255,255!!!???
                              I test that:
                              def layer_color
                                layer.color = "Blue"
                              The same result like before - Color 102,68,0 instead of blue
                              Than I test that:
                              def layer_color
                                my_mat = materials.add "Ahorn"
                                my_mat.texture = "O;\\Sketchup\\Mat\\Ahorn.jpg"
                                layer.color = my_mat
                              There was no error but also no layer!!
                              Andreas
