    Layer color by ruby-code?
    16 Posts 3 Posters 1.5k Views 3 Watching
      would help if we got the whole error - with the line number and traceback
        Andreas
        @tig said:
        There is no built-in API layer.color=
        BUT see here for my stop-gap new method... http://forums.sketchucation.com/viewtopic.php?p=177016#p177016
        with that loaded your example layer.color= [255,255,255] should work...
        I tried that. I copied "layer-color=.rb" to plugins folder.
        And than there was the error when I start my code.
        What is the mistake I made?
        With best regards from Germany
        Andreas
          what is the full error?
          line of error, and traceback?
            Have you restarted SUp after installing the new code script ?
              Andreas
              Yes
              Andreas
                Andreas
                The file "test.rb" is in plugins folder.
                That´s the whole code of test.rb
                  model = Sketchup.active_model
                  layer = model.layers.add "ABS_Grundriss_Wand2"
                  layer.color = [255,255,255]
                The following error message appears if Sketchup start:
                %(#FF0000)[Fehler beim Laden der Datei test.rb
                undefined method `page_behavior=' for nil:NilClass]
                That error appears in context with "layer-color=.rb" which is in
                plugins folder too. If I remove "layer-color=.rb" from plugins folder
                there is the following error message:
                undefined method `color=' for #Sketchup::Layer:0x6dfe1ec]
                That error I understand.
                Andreas
                  But there should be a traceback.
                  If you have a file like this:
                  def test_me
                    x == y
                  and then call that method you should get this error:
                  Error: #<NameError: undefined local variable or methodx' for main:Object>
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/testme.rb:2
                  (eval):2537`
                  Notice it includes the filename and line number after reporting the error. Do you not get that kind of error?
                    I see an issue with this method:
                    It has multiple .start_operation and commit_operation inside the code flow - which will interfere with any start_operation you started yourself - since SU doesn't handle nested start_operations:
                    ` model.start_operation
                    layer.color = 'red' # this breaks the undo stack
                    model.commit_operation`
                    Though, it is not related to the error you got.
                      Andreas
                      > def test_me
                      >   x == y
                      > end
                      (eval):2537`
                      The first way I test was run automatically at the Sketchup start.
                      There was only the error message I posted.
                      Andreas
                        Andreas
                        Sorry, I don´t understand that.
                        I tried now that:
                        def layer_color
                          layer = model.layers.add "Test_Layer"
                        if( not file_loaded?("test.rb") )
                          plugins_menu = UI.menu("Plugins")
                        	plugins_menu.add_item("LayerColor") {layer_color}
                        file_loaded("test.rb")
                        That works without error - but the new layer has the color 102,68,0
                        and not 255,255,255!!!???
                        I test that:
                        def layer_color
                          layer.color = "Blue"
                        The same result like before - Color 102,68,0 instead of blue
                        Than I test that:
                        def layer_color
                          my_mat = materials.add "Ahorn"
                          my_mat.texture = "O;\\Sketchup\\Mat\\Ahorn.jpg"
                          layer.color = my_mat
                        There was no error but also no layer!!
                        Andreas
