    Edge Fillet?
    7 Posts 5 Posters 1.6k Views 5 Watching
    • thomthomT
      Isn't there a plugin that fillets edge connections?
        Have you an image example?
        • D
          Daniel S
          try with fillet.rb from:
          404 Not Found
          (www.ohyeahcad.com)
          Daniel S
          • TIGT
            There are lots of them - try my 2Dtools 'Fillet Tool' - which fillets edges to a typed in radius and it chamfers too to an offset or two uneven offsets; it works in 3D as any two intersecting edges are coplanar. It knows which 'spare' edges can be erased as it tidies. Using it without a radius effectively makes it into a trim/extend tool too...
              Seems round corner by Fredo 6 can make the trick? πŸ˜‰
              • thomthomT
                No - RoundCorner uses faces - I wanted to round Edges.
                TIG's tool worked perfectly.
                  Filleting is in 1001bit also, just for info!
