    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 131.0k Views 42 Watching
      Thanks anyway (and again) for the plug however. I do not know if there is a solution in ruby but if not, I guess you have already updated the info on the first page.
      Maybe a solution to temporarily disable ground and sky?
        Maybe the user want either one on/off...
        • Rich O BrienR Online
          Thom,
          This is exporting for me? Ground/Sky off, BG is White and adding .png to file name when exporting but no joy! I know i've missed something here but re-reading the thread i can't pin it down?
            Can you post this joyless model? And/or screenshot?
              Just a warehouse model for testing before you know what πŸ˜‰
                Gimme model
                  It was actually one of Pete's submissions.
                  http://forums.sketchucation.com/viewtopic.php?p=198656#p198656
                  But later I'll provide the model itself in case there's a difference
                    I had no problems getting the transparency. I just loaded the model and exported.
                    Exactly what do you do?
                      Haven't the foggiest? It's meant to run from plugins menu, right?
                          Not there, it's Plugins > Thomthom's Plugins > Export 2D.
                          I've got conflict somewhere?
                            That's the correct menu item - it's just that you got ThomThom's menu installed which moves all my menu items to that position.
                            But it should not affect the result. Can you send me a quick video recording of what you do when you try to export with transparency?
                            • honoluludesktopH Offline
                              honoluludesktop
                              thomthom,
                              @thomthom said:
                              @pixero said:
                              Was transparency there all along but the built in exporter couldn't handle it?
                              Added with the SU8 API.
                              Is the api documentation wrong? If not color.alpha= What method did you use?
                                view.html.write_image
                                http://code.google.com/apis/sketchup/docs/ourdoc/view.html#write_image
                                As of SU8, if you use the hash variant for the arguments you can specify transparency.
                                  honoluludesktop
                                  Thanks, I see that the api notes that the method applies to v6.0+. How can that be correct?
                                    The method is old, but the transparency argument is new.
                                      donnasanta
                                      Thank you Thom Thom!
                                      New to SketchUp 8 (1) month. Had the 'no transparency in 2D export" problem. Found SketchUcation β˜€ , found your plug in πŸ˜„ , fixed my problem.
                                      Thank you very much.
                                      -Donna
                                        πŸ˜„ πŸ‘
                                          JGA
                                          Brilliant, works a treat. Thank-you
                                          Regards,
                                          JGA
                                            bupaje
                                            Thank you for this. Opens up a lot of possibilities. πŸ‘
                                            Burt
                                            Stormvisions
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
