    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 139.8k Views 42 Watching
      Haven't the foggiest? It's meant to run from plugins menu, right?
          Not there, it's Plugins > Thomthom's Plugins > Export 2D.
          I've got conflict somewhere?
            That's the correct menu item - it's just that you got ThomThom's menu installed which moves all my menu items to that position.
            But it should not affect the result. Can you send me a quick video recording of what you do when you try to export with transparency?
            • honoluludesktopH Offline
              honoluludesktop
              thomthom,
              @thomthom said:
              @pixero said:
              Was transparency there all along but the built in exporter couldn't handle it?
              Added with the SU8 API.
              Is the api documentation wrong? If not color.alpha= What method did you use?
                view.html.write_image
                http://code.google.com/apis/sketchup/docs/ourdoc/view.html#write_image
                As of SU8, if you use the hash variant for the arguments you can specify transparency.
                  honoluludesktop
                  Thanks, I see that the api notes that the method applies to v6.0+. How can that be correct?
                    The method is old, but the transparency argument is new.
                      donnasanta
                      Thank you Thom Thom!
                      New to SketchUp 8 (1) month. Had the 'no transparency in 2D export" problem. Found SketchUcation β˜€ , found your plug in πŸ˜„ , fixed my problem.
                      Thank you very much.
                      -Donna
                        πŸ˜„ πŸ‘
                          JGA
                          Brilliant, works a treat. Thank-you
                          Regards,
                          JGA
                            bupaje
                            Thank you for this. Opens up a lot of possibilities. πŸ‘
                            Burt
                            Stormvisions
                              bupaje
                              I have a suggestion for this great plugin (if still in development). πŸ˜„
                              Would it be possible to export multiple layers as a series of png's? I see that ImageReady CS2 has an option to import a series of images to layers, which can then be saved out as a psd file. This would make SketchUp great for blocking in some layers -say foreground/midground/background elements and individual objects, then opening in Photoshop to do paintovers with the objects seperated by layer.
                              Burt
                              Stormvisions
                                sank64
                                Takk for det!
                                • mooshonovM Offline
                                  mooshonov
                                  Hey thom and thanks for this great plugin.
                                  I need to produce some 2d transparency alpha maps. Installed TT_lib2 folder along side tt_lib and tt_export.rb into the plugins directory.
                                  Don't have the dialoug which you mark "Transparency" while exporting png from file>export>2d graphic.
                                  many thanks
                                  **V-Ray for SketchUp eBook author
                                  Buy your copy now at vfsbook.com**Licensed Instructor
                                  Chaos Group Partner
                                  CEO @ V-Ray Israel
                                    See the description again in the first post. The menu is not located under File, it is "View -> Export 2d".
                                      Thom,
                                      Ever notice some funny screen cropping using this?
                                        Cropping? It exports the incorrect area?
                                          Exactly, if I play with resolution size at times it'll crop away some of the image. But I'm keeping the the same ratios.
                                            Can you post a reproducible example?
                                            • 3 / 8
