    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 143.9k Views 42 Watching
      @gaieus said:
      Maybe a solution to temporarily disable ground and sky?
      Maybe the user want either one on/off...
        Thom,
        This is exporting for me? Ground/Sky off, BG is White and adding .png to file name when exporting but no joy! I know i've missed something here but re-reading the thread i can't pin it down?
          Can you post this joyless model? And/or screenshot?
            Just a warehouse model for testing before you know what πŸ˜‰
              Gimme model
                It was actually one of Pete's submissions.
                404 Not Found
                (forums.sketchucation.com)
                But later I'll provide the model itself in case there's a difference
                  I had no problems getting the transparency. I just loaded the model and exported.
                  Exactly what do you do?
                    Haven't the foggiest? It's meant to run from plugins menu, right?
                        Not there, it's Plugins > Thomthom's Plugins > Export 2D.
                        I've got conflict somewhere?
                          That's the correct menu item - it's just that you got ThomThom's menu installed which moves all my menu items to that position.
                          But it should not affect the result. Can you send me a quick video recording of what you do when you try to export with transparency?
                          • honoluludesktopH
                            honoluludesktop
                            thomthom,
                            @thomthom said:
                            @pixero said:
                            Was transparency there all along but the built in exporter couldn't handle it?
                            Added with the SU8 API.
                            Is the api documentation wrong? If not color.alpha= What method did you use?
                              view.html.write_image
                              http://code.google.com/apis/sketchup/docs/ourdoc/view.html#write_image
                              As of SU8, if you use the hash variant for the arguments you can specify transparency.
                              • honoluludesktopH
                                honoluludesktop
                                Thanks, I see that the api notes that the method applies to v6.0+. How can that be correct?
                                  The method is old, but the transparency argument is new.
                                    donnasanta
                                    Thank you Thom Thom!
                                    New to SketchUp 8 (1) month. Had the 'no transparency in 2D export" problem. Found SketchUcation β˜€ , found your plug in πŸ˜„ , fixed my problem.
                                    Thank you very much.
                                    -Donna
                                      πŸ˜„ πŸ‘
                                        JGA
                                        Brilliant, works a treat. Thank-you
                                        Regards,
                                        JGA
                                        • B
                                          bupaje
                                          Thank you for this. Opens up a lot of possibilities. πŸ‘
                                          Burt
                                          Stormvisions
                                          • B
                                            bupaje
                                            I have a suggestion for this great plugin (if still in development). πŸ˜„
                                            Would it be possible to export multiple layers as a series of png's? I see that ImageReady CS2 has an option to import a series of images to layers, which can then be saved out as a psd file. This would make SketchUp great for blocking in some layers -say foreground/midground/background elements and individual objects, then opening in Photoshop to do paintovers with the objects seperated by layer.
                                            Burt
                                            Stormvisions
                                            • 3 / 8
