    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 139.8k Views 42 Watching
    • Rich O BrienR Online
      Thom,
      This is exporting for me? Ground/Sky off, BG is White and adding .png to file name when exporting but no joy! I know i've missed something here but re-reading the thread i can't pin it down?
        Can you post this joyless model? And/or screenshot?
          Just a warehouse model for testing before you know what πŸ˜‰
            Gimme model
              It was actually one of Pete's submissions.
              404 Not Found
              (forums.sketchucation.com)
              But later I'll provide the model itself in case there's a difference
                I had no problems getting the transparency. I just loaded the model and exported.
                Exactly what do you do?
                  Haven't the foggiest? It's meant to run from plugins menu, right?
                      Not there, it's Plugins > Thomthom's Plugins > Export 2D.
                      I've got conflict somewhere?
                        That's the correct menu item - it's just that you got ThomThom's menu installed which moves all my menu items to that position.
                        But it should not affect the result. Can you send me a quick video recording of what you do when you try to export with transparency?
                        • honoluludesktopH Offline
                          honoluludesktop
                          thomthom,
                          @thomthom said:
                          @pixero said:
                          Was transparency there all along but the built in exporter couldn't handle it?
                          Added with the SU8 API.
                          Is the api documentation wrong? If not color.alpha= What method did you use?
                            view.html.write_image
                            http://code.google.com/apis/sketchup/docs/ourdoc/view.html#write_image
                            As of SU8, if you use the hash variant for the arguments you can specify transparency.
                              honoluludesktop
                              Thanks, I see that the api notes that the method applies to v6.0+. How can that be correct?
                                The method is old, but the transparency argument is new.
                                  donnasanta
                                  Thank you Thom Thom!
                                  New to SketchUp 8 (1) month. Had the 'no transparency in 2D export" problem. Found SketchUcation β˜€ , found your plug in πŸ˜„ , fixed my problem.
                                  Thank you very much.
                                  -Donna
                                    πŸ˜„ πŸ‘
                                      JGA
                                      Brilliant, works a treat. Thank-you
                                      Regards,
                                      JGA
                                        bupaje
                                        Thank you for this. Opens up a lot of possibilities. πŸ‘
                                        Burt
                                        Stormvisions
                                          bupaje
                                          I have a suggestion for this great plugin (if still in development). πŸ˜„
                                          Would it be possible to export multiple layers as a series of png's? I see that ImageReady CS2 has an option to import a series of images to layers, which can then be saved out as a psd file. This would make SketchUp great for blocking in some layers -say foreground/midground/background elements and individual objects, then opening in Photoshop to do paintovers with the objects seperated by layer.
                                          Burt
                                          Stormvisions
                                            sank64
                                            Takk for det!
                                            • 3 / 8
