    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 143.9k Views 42 Watching
    • HumpmetwiceH
      Humpmetwice
      Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
      • thomthomT
        After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
        • HumpmetwiceH
          Humpmetwice
          I know and it doesn't give me any file type to save it as at all.
          • thomthomT
            You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
            So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
            • GaieusG
              @thomthom said:
              @gaieus said:
              Edit; to me, it does not export with transparent background... Nor does it export only the active context. 😞
              What version of SU did you use?
              Got a screencapture?
              The most recent one; SU 8.
              Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
              test2.avi
              • thomthomT
                That baffles me. I have no idea why this happens. Exactly the same works for me... ❓ πŸ˜• ❓
                test1.zip
                • GaieusG
                  Well, sigh... I can always use LO for exporting png's with transparent background...
                  Maybe it's an XP thing?
                  • thomthomT
                    I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
                    • GaieusG
                      Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
                      πŸ˜„
                      • thomthomT
                        Just to narrow it down to a simple test case - can you try this one-liner?
                        <span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">write_image</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">{</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">=></span><span class="syntaxstring">'C;\test.png'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">width</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">640</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">height</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">480</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">antialias</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">false</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">transparent</span><span class="syntaxkeyword">=></span><span class="syntaxdefault">trueΒ </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">Β </span><span class="syntaxkeyword">)</span><span class="syntaxdefault">Β </span>
                        • GaieusG
                          Try what? Enter the ruby console? I get this:
                          • TIGT
                            If you set the background color to be 0,0,0 [pure-black] then the image will export with a transparent background in place of the 'pure-black', when you open it in Gimp or a web-browser etc you will see there is no background... πŸ€“test.png
                            • thomthomT
                              Should not need to do this - I export with the default SketchUp Sky - still I get transparency.
                              • TIGT
                                That's not entirely correct... iIF you have a Sky and/or Ground ticked in your Style you will not get a transparent background to the png for the areas that these parts 'cover'.
                                BUT if you have the Sky AND Ground un-ticked in your Style then I agree - the color of the Background itself is irrelevant because whatever it is when the have the png export transparency set 'on' that background is made 'transparent' - no matter what color it is - white, black, magenta or anything else!
                                • thomthomT
                                  I get Transparency with Sky on. But not with Ground.
                                  ...Gaieus... do you have the Ground on?
                                  • thomthomT
                                    Correction: Sky do appear when exporting. I just always tried with a view looking down so no sky was visible.
                                    • TIGT
                                      I find that both sky and ground obscure my png's background transparency ?
                                      I need to have sky and ground both off to have a fully transparent background in the png, BUT even then shadows on the ground-pane will show up floating is space so you need to have that option off too...
                                      • FrederikF
                                        Frederik
                                        Don't know why I haven't seen this gem before today... 😳
                                        Awesome, Thomas...!
                                        Thank you SO much...!!
                                        Cheers
                                        Kim Frederik
                                        • GaieusG
                                          Hi Thom and TIG; you are right, when I turn ground and sky off, I can export with transparency.
                                          And now I am banging my head to the wall (where is that smiley?
                                          http://twilightrender.com/phpBB3/images/smilies/wall.gif
                                          This is exactly the way you need to set your style to be able to export your png with transparency!
                                          • thomthomT
                                            Yea - we need that smiley.
                                            This has been one for my Duh! list as well.
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
