Balustrade with components plugin seems to fail in SU8
Hello,
Long time no posting, but reading all your interesting ideas about SketchUp.
In SketchUp 8, when I try to work with balustrade with components plugin, I receive the next message:Error Loading File balustrade_components.rb
C:/Program Files/Google/Google SketchUp
8/Plugins/balustrade_components.rb:228:syntax error,
unexpected',',expecting')'
if (n1.between?(n2-interval),(n2+interval))Any advice?
It's a known issue - the problem is that the newly shipped version of Ruby is less forgiving of bad syntax.
So whiledosomething (a+b), cused to work it now returns an error as it thinks the first () contains the argument[s] and the trailing ", c" is then 'wrong'...
dosomething a+b, cwill work [as long as the first argument can work without its ()]
BUT it's better to put all of a function's arguments inside (...)
so the better version is
dosomething((a+b), c)
Note how there should not be a <space> before the first enclosing (...
Didier has some scripts showing this type of error-message when used in v8.
Some are encrypted and can't be readily edited - howeverbalustrade.rbis in plain-text and I have attached a version where all arguments are now correctly parenthesized [i.e. not just the 'problem' one]...balustrade_components.rb -
This is the error I receive with the modified file.
Thanks for your help.
Ken
Ken
Sorry about that... my mistake - the version is now corrected - please download it again...
Thanks for the update TIG, I have been keeping a lookout for any and all fixes to the SU8 problem. I do use this plugin but haven't tried since the update. Now I don't need to worry
@tig said:
Ken
I went thru the plugin to see if I could find the problem, however, I darn sure wasn't going to post a correction. Not even close to being that smart.
So thank you TIG
Ken
Thanks Ken
Another error has appeared...
I have corrected this new error - so please download the updated version again
http://forums.sketchucation.com/viewtopic.php?p=270788#p270788
which should now be sorted
[Thanks Ken, again]
Thanks a lot, TIG, I use this script a lot.
So sorry, but steel not work for me. merci d'avance.
Doesn't work for me either. The component face of handrail doesn't extrude to the line path and generaly it "sees" only one part of polyline even after weld plugin. help please!
Thanks for the update.
Guys this does not show up at Sketchucation Plugin Store, though it's a great plugin!
Shouldn't it be there?
Best regards,
JQL
Register LoginAdvertisement
