    Balustrade with components plugin seems to fail in SU8
    12 Posts 8 Posters 4.2k Views 8 Watching
      It's a known issue - the problem is that the newly shipped version of Ruby is less forgiving of bad syntax.
      So while dosomething (a+b), c used to work it now returns an error as it thinks the first () contains the argument[s] and the trailing ", c" is then 'wrong'...
      dosomething a+b, c will work [as long as the first argument can work without its ()]
      BUT it's better to put all of a function's arguments inside (...)
      so the better version is
      dosomething((a+b), c)
      Note how there should not be a <space> before the first enclosing (...
      Didier has some scripts showing this type of error-message when used in v8.
      Some are encrypted and can't be readily edited - however balustrade.rb is in plain-text and I have attached a version where all arguments are now correctly parenthesized [i.e. not just the 'problem' one]...balustrade_components.rb
      • kenK
        ken
        This is the error I receive with the modified file.
        Thanks for your help.
        Ken
          Ken
          Sorry about that... my mistake - the version is now corrected - please download it again... ๐Ÿ˜ณ
          • jim smithJ
            jim smith
            Thanks for the update TIG, I have been keeping a lookout for any and all fixes to the SU8 problem. I do use this plugin but haven't tried since the update. Now I don't need to worry โ˜€
            "Out of clutter find simplicity,
            from discord find harmony,
            In the middle of difficulty lies opportunity"
            Albert Einstein
            • kenK
              ken
              @tig said:
              Ken
              I went thru the plugin to see if I could find the problem, however, I darn sure wasn't going to post a correction. Not even close to being that smart.
              So thank you TIG
              Ken
                Thanks Ken ๐Ÿ˜‰
                Another error has appeared...
                I have corrected this new error - so please download the updated version again
                http://forums.sketchucation.com/viewtopic.php?p=270788#p270788
                which should now be sorted ๐Ÿ˜ณ
                [Thanks Ken, again]
                  julyyen
                  Thanks a lot, TIG, I use this script a lot. ๐Ÿ˜„
                    STUDIO.B
                    So sorry, but steel not work for me. merci d'avance.
                    • E
                      elthanos
                      Doesn't work for me either. The component face of handrail doesn't extrude to the line path and generaly it "sees" only one part of polyline even after weld plugin. help please!
                        alumiroi
                        Thanks for the update.
                        • JQLJ
                          JQL
                          Guys this does not show up at Sketchucation Plugin Store, though it's a great plugin!
                          Shouldn't it be there?
                          Best regards,
                          JQL
                          www.casca.pt
                          Visit us on facebook!
