    SketchUp 7 to SketchUp 8 migration ....how to best do this
    13 Posts 8 Posters 1.8k Views 8 Watching
      redinhawaii
      Okay, my plugins did not come with me from SU7 to SU8... I would think there is an easy way to do that... just copy and paste... or...
      and
      I got into SU8, with a model, not having all of the plugins I typically use, I went back to SU7 to finish modeling. alas, I cannot copy and past from one to the other....
      any insights on this situation?
      • jim smithJ Offline
        jim smith
        I can't understand why you are not able to copy the plug ins. ❓ I upgraded last week and just copied them and they worked fine except for a few that need to be updated for SU8.
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
        • jeff hammondJ Offline
          jeff hammond
          Yeah, copy/paste
          Open the su7 plugin folder... Cmmd C
          Open the su8 plugin folder... Cmmd V
          @Jim. I think in that part, red was talking about the inability to copy/paste lines etc. Between su7 & 8
          dotdotdot
            redinhawaii
            That seems easy, but did not seem to work, I quit SU8, after Command paste the plugins, they show up but when I relaunch SU8 the menu bar does not show the plugins menu, i.e. where it use to be in SU7.
            And the main issue was that the model created in SU8 does NOT copy and paste into SU7. Is that so, or again am I doing something wrong.
            thanks
            aloha
            red
              redinhawaii
              Menu, ...Window, PLUGINS, Help... plugins does not show up in SU8,
              do I have to reboot the computer to get them to register/ or just quit the software?
              • wind-borneW Offline
                wind-borne
                thanks
                aloha
                red
                make sure your plugins are on this path
                your work in 8 do a save as 7 then you can paste work onto 7
                "To read between the lines was easier than to follow the text."OSX 10.11.6
                %(#BF80BF)[SU 8 pro
                  jeff hammond
                  oh, I guess I forgot about cmmd A in there.
                  But if you're saying you have in fact pasted them then I guess you figured that part out.
                  dotdotdot
                    redinhawaii
                    Okay, got the "saved to SU 7" figured out,
                    thanks for the suggestion.
                    the plugins thing, got them migrated across, now SU8 crashes upon opening.
                    do I have to go thru the laborious process of loading them one at a time to see which one is causing the crash, or is there anyway to "check the code"... as if I even had a clue as to what to do if that was the case... thanks,
                    Oh, I did save the copied rubies in a separate folder, on the hard drive... if needed
                    aloha
                    red
                    • Dan RathbunD Offline
                      Dan Rathbun
                      Just a note on the Google provided plugins (and their subfolders.)
                      I KNOW for a fact, that there is a minor cosmetic fix, in the "ocean_extension.rb" file, because I found the error, and provided the suggestion on how to fix it.
                      Do not assume Google provided rubies will not change, from release to release!
                      These files, and their subfolders, should not be overwritten with the SU7 versions.
                      examples.rb
                      ocean_extension.rb
                      utilities.rb
                      /Examples
                      /Ocean
                      /Utilities
                      I'm not here much anymore.
                      • PixeroP Offline
                        Pixero
                        Is there a way to set SU8 to save as SU7 by default? Internal or thrugh ruby?
                        (Like how I can set MS Word 2007 to save as MS Word 2003 by default.)
                        Needed if several users work together and don't have the same version.
                        • jgbJ Offline
                          jgb
                          While we are on the subject of migrating pluggins to SU8, anybody have any thoughts/experience migrating Version 6 pluggins to SU8?
                          I am seriously considering the upgrade. Finally......
                          I can provide a list that I have loaded, and the list of "Can't live without" if you need it.
                          jgb
                            aea
                            Today I decided to go to SU 8 but found that no program opens in render hypermove 2010, we saved a model we need in SU 8 and I still can not save in SU 7.
                            Can I do anything?
                            Please help
                              aea
                              i discover save as ....
