    SU 9 Wishlist
    436 Posts 99 Posters 95.5k Views 99 Watching
      @fluffy82 said:
      I would love for some improvement in the follow me tool:
      1. when doing a follow me, I'd like it to create a new group automatically --> now you need to make a group out of the profile, open the group, retrace the path within the group and then extrude. That's a lot of work, sometimes... Especially when you have complicated paths.
      I think your work flow could be more efficient than you describe. I frequently have need to draw things like crown moldings but haven't done it the way you describe and have no problems.
      @fluffy82 said:
      1. I'd love for it to "remember" the initial parameters so I can modify either the profile or the path afterwards, affecting the result, without having to redraw the complete thing.
      What parameters?
        2. I'd love for it to "remember" the initial parameters so I can modify either the profile or the path afterwards, affecting the result, without having to redraw the complete thing.
        3. Changing the profile also involves changing the number of faces/segments. For example, if you extrude a crown moulding with a round part in it, you should be able to change the number of segments in the profile if needed.
        You need this plugin:
        http://www.smustard.com/script/ProfileBuilder
        Free version is also available:
        http://sketchucation.com/forums/viewtopic.php?t=44237
          Exactly. Excellent plugin and does what you listed.
          • jeff hammondJ Offline
            jeff hammond
            @dave r said:
            What parameters?
            he's talking about history modeling.. (or at least that's the term i know it as)
            -draw a path & profile
            -follow me
            -move, say, a vertex of the path
            -the extrusion updates accordingly
            dotdotdot
            • F Offline
              fluffy82
              If you extrude the profile without making it into a group first, it becomes virtually impossible to group afterwards (I make rather complicated crown mouldings with loads of corners, "popping out" on top of a column etc)
              @dave r said:
              What parameters?
              The form of the profile, the path it follows,... If you need to make a change now, you need to delete it and start over.
              • F Offline
                fluffy82
                Super, I'll check it out immediately!
                -follow me
                Yes... I am very bad at explaining myself... But that's exactly what I mean.
                  It certainly is possible to make it a group afterward. And it is quite simple. Why would you think it is "virtually impossible"? πŸ˜’
                    If the operation is done in a model where other objects aren't grouped. Then it merge with other geometry. That's why I keep telling the people at my office to always group (or make components) out of everything - and organize the model properly.
                      Indeed!
                      • F Offline
                        fluffy82
                        Of course it is possible, but it is a lot of work selecting all faces and edges because there are a lot of them (see example). I am probably doing something wrong then.
                        I know there are several ways to select multiple objects (select right-to-left, triple click,...) but those always seem to include things I don't want it to select (geometry or groups/components which happen to be in the way).
                        So the only way is to double click on each and every face to select it and its edges, while holding the Ctrl-key...
                        Anyway, I will check out the profilebuilder, maybe that will make my life easier πŸ˜„
                        You are right, I usually group most parts of the model, but things like walls (including holes for doors/windows etc) are not grouped. I should really remember doing that systematically...
                        PS I only use SketchUp about an hour a week or so, I am comfortable with the program but far from an experienced user... I spend more time reading about how to do this or that than I actually build things myself πŸ˜„
                        a fast example
                          I know there are several ways to select multiple objects (select right-to-left, triple click,...) but those always seem to include things I don't want it to select(geometry or groups/components which happen to be in the way).
                          You've hit on your problem. Make it a practice to make a component (or a group) of things that need to remain separate. This is the only way to keep things separated in SketchUp. If you did that, a triple click with the Select tool on your molding would select only that and nothing else.
                          You mentioned before that you don't want to have to redraw the path for Follow Me in cases where you have to change the molding. Well, don't. After you've traced around the room once, move the path straight up above the room and the molding profile.
                          then, running Follow Me won't consume the path. You could make it a component of its own and put it on a "Path" layer or just save it for later until you know you're finished with it. If you want to put a chair rail around the room, you could use this same path and then cut for doors and windows as needed afterward.
                          By the way, when you make molding profiles as components, consider making them so they are standing vertically so when you insert them into your models later you don't have to rotate them into the proper position. That'll save you some work.
                            As Dave says keeping each "object" in the model as a group gives you a good organization. Also, keep faces and edges on Layer0 and place the groups and components on layers. (I also encourage people to never change the active layer to anything other than Layer0 - because when you start changing the active layer it's all to easy to forget to change it to the correct one.)
                            • F Offline
                              fluffy82
                              @dave r said:
                              After you've traced around the room once, move the path straight up above the room and the molding profile. Then, running Follow Me won't consume the path. You could make it a component of its own and put it on a "Path" layer or just save it for later until you know you're finished with it.
                              Ok, I never thought of that... Great idea, thanks!
                              The path "disappearing" was one of my issues, making it into a group ment I couldn't do a follow me on it anymore. Moving it up, using it as a path and then make a group and hide it on a separate layer will work great.
                              This seems to have moved a bit off topic, sorry about that. But it's clear to me now.
                                jedicharles
                                How about built in file compression that can be used optionally to keep filesize down? And not just for Pro, but everyone.
                                http://sketchup3dchallenge.blogspot.com/
                                • jo-keJ Offline
                                  jo-ke
                                  yes, filesize is my problem too, every day!
                                  http://www.zz7.de
                                  • Bryan KB Offline
                                    Physics.
                                    Pretty please?
                                    • 18
                                    • 19
                                    • 20
                                    • 21
                                    • 22
                                    • 22 / 22
