    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 121.3k Views 34 Watching
      Very Romantic yes 😄
      But there is a little problem 😮
      That works not with that! 😲
      (I have also tried with explode Circle, convert, erase..., not better) !
      Good result must be 5 CPpoints !
      Else of course your plug if very fun (and useful) for this sort of thing 😉
      CPoint at Circle Center
      Insert Components at CPoints 👍
      And of course Selection Toys for Select CPoints 😉
      http://forums.sketchucation.com/download/file.php?id=56417
      • thomthomT
        Very Romantic yes 😄
        [attachment=0:26fwmhk5]<!-- ia0 -->worksnot1.jpg<!-- ia0 -->[/attachment:26fwmhk5]
        Are these edges that's split each other?
        From your original request I thought you wanted cpoints at edge crossings if the edge where not part of a face.
        Maybe it should just not check if edges are connected to faces?
        Should it only place a cpoint for overlapping edges (but does not split each other? )
        And one existential question with the Cpoint at Arcs Center! 🤓
        (of course from a same circle trimed) 😉
        [attachment=0:26fwmhk5]<!-- ia0 -->existential.png<!-- ia0 -->[/attachment:26fwmhk5]
        I don't understand the question...
          In fact just put a CPoint at any real intersections of a selection of lines and/or circles, arc circle and /or curves
          on faces or in the space
          (i don't know if it's an hard work or not) 😳
          for the existential question 😄
          an Arc Circle A has a Cpoint CPA, xa , ya, za
          an Arc Circle B has a Cpoint CPB xb, yb, zb
          but of course as you can see on my previous image
          because arc are from a same circle
          xa = xb, ya = yb, za = zb
          So my question what about this "double CPoint"?
          is there 2 Cpoints or you merge it in only one?
          • thomthomT
            Where edges are split where they intersect? Or where they overlap - like they often do in SU6 and older?
            Doesn't check for existing CPoints.
              I don't know, on the face I suppose 😳
              In any case we have solution to move them out the face (when existing)
              call the plug, and re put on the face 😄
              So there are 2CPoint overlaped
              or they are automatical merged as one by SU as having same coordinates ?
              (same than you draw 2 lines ovelapped)
              • thomthomT
                Something is lost in translation here - I mean should there be a CPoint only when two edges cross each other but doesn't split each other?
                I don't know - I haven't tested it. The plugin just adds a CPoint blindly.
                  I have just tested seems there are really 2 CPoints! 😮
                  Maybe some annoyous 😉
                  click image if scrool bar!
                  • TIGT
                    I think Pilou's issue with 'duplicated Cpoints' - i.e. at the same location in 3D space - is if they are used to place Instances later it will duplicate the Instances etc.
                    When adding the new Cpoints it'd be relatively easy to test to see if there was a Cpoint already there.
                    First make a collection of Cpoints in the current context [entities] and make an array of the 'position' of each one: then only add the new Cpoint if it's not already there - code-example...
                    there=false
                    cpoint_positions.each{|p|(there=true;break)if p==new_point}
                    entities.add_cpoint(new_point) if not there
                    You should still add coincident Cpoints if they are in different contexts [entities-sets]...
                    • thomthomT
                      Slightly trimmed variant:
                      entities.add_cpoint(new_point) unless cpoint_positions.any?{|pt|pt==new_point}
                        In fact that must be 6 points! 😒
                        1 Center of circle
                        1 Intersection of lines
                        4 Intersection Lines Circle
                        Here I have a lot of more 😉
                        I have made Intersection before launch the plug Edge/edge (V 6)
                        Edit I have found a Process
                        General Intersection
                        Hide Circle
                        Call the Plug Guides Tool - Edge/edge
                        Show Circle
                        Select Circle
                        Call ad Cpoint to Circle
                        I have my six points 😎
                        Easy for not numerous circles but for many ? 😉
                        Ok I can use Selection Toys Circles ☀ 😉
                        • thomthomT
                          Why do you hide and show the circle?
                            Yes see my edit text 😉
                            In fact that must be Selection Toys "Arcs"
                            Hide
                            because the interections are made before 😉
                            Process must be
                            Ad CP Circle(s)
                            Hide
                            Add CPoint Edge /Edge
                            Show Hidden
                            When Edge / Edge Cpoints are they "Doubled" between 2 segments of a same lines or not? (like my lines above after the intersection)
                            (at the commune extremities)
                            Seems not! 😎 (I have verified with the outliner) ☀
                            You have just the problem of same arc centers of my previous old post 😉
                            • W
                              watkins
                              Dear Thomas,
                              Could the following be added to the suite of cpoint functions?
                              To place a construction point at the intersection of three orthogonal planes.
                              Thanks,
                              Bob
                              • TIGT
                                @watkins said:
                                Dear Thomas,
                                Thanks,
                                Bob
                                Should be straightforward...
                                Get line of the intersection of two of the planes.
                                get the intersection of the third plane and the line.
                                Add a cpoint...
                                  @ Thomthom
                                  Does it possible to have an option for DWG export?
                                  Problem is: Tocad don't import CP POINT !!! 😮
                                  So circle center oe arc circle center info are losted!
                                  So a possibility is to replace CPoints by 2 or 3 lines crossed.(3 axis)
                                  (as "component" even Tocad lost the "component" it draw the lines! ☀
                                  And each circle is tranformed in disc by ToCad.
                                  So Replace CPoints by crossed lines will be fine for DWG export 😄
                                  Of course the replacement can be made by Selection Cpoint/Put Component at Cpoints.
                                  (problem of mutiple same CPoints must be also resolved) 😄
                                  • thomthomT
                                    Version 1.3.0
                                    CPoint at Camera Eye - Adds a construction point at the Camera eye.
                                    • utilerU
                                      utiler
                                      Great addition Thom! All your work with rubies are very much appreciated!!!
                                      Just Curious...
                                      • L
                                        lapx
                                        Tom,
                                        Thanks! I've been searching for this for a while.
                                        Best, Lapx.
                                        • Bob JamesB
                                          Bob James
                                          Drilling Milling[/url] by Menfin (French and English version) ☀
                                          This looks like it would be very handy, but the forum is in French (only) and doesn't allow download without being a member of the forum. 😞
                                          • D
                                            dedmin
                                            Is it possible to add "CPoint at Insertion Point" for groups also?
                                            • 3 / 5
