    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 122.9k Views 34 Watching
    • thomthomT
      Overview
      A small collection of snippets I made while modelling. Compiled them into one plugin.
      Access
      Plugins > Guide Tools
      Features
      CPoint at Arc Center
      Adds a construction point at the centre of every selected arc.
      CPoint at Circle Center
      Adds a construction point at the centre of every selected circle.
      CPoint at Exploded Arc Center
      Adds a construction point at the centre of every selected exploded arc (When SketchUp thinks it's just edges).
      CPoint at Bounds Center
      Adds a construction point at the centre of every group/component's bounding box.
      CPoint at Bounds Bottom Center
      Adds a construction point at the bottom centre of every group/component's bounding box.
      CPoint at Edge-Face Intersection (v1.2.0)
      Adds a construction point where the selected edges intersect the selected faces.
      CPoint at Edge-Edge Intersection (v1.2.0)
      Adds a construction point where the selected edges connects. Note: only "loose" edges - edges that is not part of a face.
      CPoint at Insertion Point (v1.1.0)
      Adds a construction point inside every component's insertion point. If nothing is selected it processes all the components in the model.
      CPoint at Camera Eye (v1.3.0)
      Adds a construction point at the Camera eye.
      Insert Components at CPoints
      Insert an instance pf the selected group/component at every selected construction point.
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2 (v2.4.0)
      404 Not Found
      (sketchucation.com)
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_guide_tools.rb
      http://forums.sketchucation.com/download/file.php?id=53761
      • B
        Ben Ritter
        Nice, thank you very much.
        • EarthMoverE
          EarthMover
          Thanks again! 👍 👍
          Content Creator at Skapeup
          • CadFatherC
            CadFather
            Wow, Mr Thom, is it christmas where you live? some of these tools are amazing! superthanks! 👍
              You can't stop the production before 2012? 😄
              • thomthomT
                A year or so of small snippets finally organized. My way of celebrating SU 10 years and the release of v8. 😄
                  We can't follow a such flood avalanche! 😄
                  http://www.studentsoftheworld.info/sites/animaux/img/562_cheval tire langue.jpg
                  • majidM
                    majid
                    another great gift befor 2012 😉 hope to be (after 2012) at the paradise for your generosity 😄 👍
                    • S
                      snowflake
                      Xmas, more like the back to school offers that are around, but with greater added value.
                      Thank you once again for your amazing work and dedication.
                      • MALAISEM
                        MALAISE
                        Still great as ever
                        MALAISE
                        • thomthomT
                          Version 1.1.0
                          • CPoint at Insertion Point.
                          • W
                            watkins
                            Dear Thomas,
                            With AutoCAD one can change the guide point style, and then set the size to relative or absolute. Is this something that can be done with your plugin?
                            Further, when working with assemblies, I would sometimes like to select all the cpoints and then hide them. Again, is that possible with your plugin? Options like hide_all and hide_selection would be useful.
                            Kind regards,
                            Bob
                            • W
                              watkins
                              Dear Thomas,
                              The attached images show the effect of 'cpoint relative'. It would be nice to set the cpoint to an absolute size, say 1 mm, so that the cpoints are only visible when one zooms in to the model.
                              Regards,
                              Bob
                              cpoint_relative.zip
                                And CPoint at intersection of Guides lines?
                                CPoint at intersection of selected?
                                • thomthomT
                                  No - the appearance of CPoints can not be changed in SU.
                                  There is a Hide/Show Guides under the View menu if I remember correctly.
                                  Isn't there plugins that do this?
                                    Maybe but all in one package is more practical 😉
                                    • C
                                      caleidos4d
                                      THANKS!! 👍
                                      http://www.caleidos4d.it
                                      • EarthMoverE
                                        EarthMover
                                        Would there be a way to add an array copy to guides or cpoints?
                                          Does it possible to have circular Guides line?
                                          • jeff hammondJ
                                            jeff hammond
                                            hey adam.. didier's projections:
                                            http://forums.sketchucation.com/viewtopic.php?t=20140
                                            .. has some neat stuff in there regarding guide arrays and whatnot..
                                            i like guides by division a lot & guides by interval is handy too..
                                            maybe check that plugin out? (again?)
                                            dotdotdot
                                            • 1 / 5
