    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 121.3k Views 34 Watching
      snowflake
      Xmas, more like the back to school offers that are around, but with greater added value.
      Thank you once again for your amazing work and dedication.
      • MALAISEM
        MALAISE
        Still great as ever
        MALAISE
          Version 1.1.0
          • CPoint at Insertion Point.
          • W
            watkins
            Dear Thomas,
            With AutoCAD one can change the guide point style, and then set the size to relative or absolute. Is this something that can be done with your plugin?
            Further, when working with assemblies, I would sometimes like to select all the cpoints and then hide them. Again, is that possible with your plugin? Options like hide_all and hide_selection would be useful.
            Kind regards,
            Bob
            • W
              watkins
              Dear Thomas,
              The attached images show the effect of 'cpoint relative'. It would be nice to set the cpoint to an absolute size, say 1 mm, so that the cpoints are only visible when one zooms in to the model.
              Regards,
              Bob
              cpoint_relative.zip
                And CPoint at intersection of Guides lines?
                CPoint at intersection of selected?
                  No - the appearance of CPoints can not be changed in SU.
                  There is a Hide/Show Guides under the View menu if I remember correctly.
                  Isn't there plugins that do this?
                    Maybe but all in one package is more practical 😉
                    • C
                      caleidos4d
                      THANKS!! 👍
                      http://www.caleidos4d.it
                      • EarthMoverE
                        EarthMover
                        Would there be a way to add an array copy to guides or cpoints?
                        Content Creator at Skapeup
                          Does it possible to have circular Guides line?
                          • jeff hammondJ
                            hey adam.. didier's projections:
                            http://forums.sketchucation.com/viewtopic.php?t=20140
                            .. has some neat stuff in there regarding guide arrays and whatnot..
                            i like guides by division a lot & guides by interval is handy too..
                            maybe check that plugin out? (again?)
                              WorkPlane Disk!
                              • KrisidiousK
                                Krisidious
                                you ROCK Thom!!!
                                By: Kristoff Rand
                                  Other than the native Move+Copy array?
                                  • EarthMoverE
                                    EarthMover
                                    😆 For some reason, the whole time I've used Sketchup, I thought array copy with the move tool didn't work with guides. Apparently it does! 😳 Learn something everyday. I think I tried it using the #/ to equally space copies between points which doesn't work and assumed forward array didn't work either. Dieders tools are great too and hence all my requests are instantly met. 😄
                                    (On a side note, can you implement a multiple copy array feature to your divide face tool? That would be very handy! 😛)
                                    • jeff hammondJ
                                      hmm.. that works with C_lines (and cpoints as well)..
                                      maybe you didn't copy/move it to begin with and only moved it?
                                      [edit] i was gonna say that you're supposed to type it like /# instead of #/ but i just tried it and they both work..
                                      • EarthMoverE
                                        EarthMover
                                        Jeff, you're right. I've always tried to make arrays with the tape measure tool by itself after pulling a cline off of an edge. Using the move tool works as expected. A truly "duh" moment for me! 😲 😆
                                        • jeff hammondJ
                                          That'd be sweet though. Something that google could/should add to standard SU as it wouldn't compromise simplicity for a bit more complexity. There are a few native tools that could acquire added functions while staying true to the vision. (multiface pushpull is another example)
                                            It already has. After placing a line you can type * or / to add more lines. Even adjust the amounts.
                                            • 1 / 5
