    [Plugin] Solid Inspector
    303 Posts 99 Posters 272.5k Views 98 Watching
    • voljankoV Offline
      voljanko
      There are also some ungrouped lines that can prevent your model to be solid.That means that they are outside the group or inside the group with the solid subgroup.In your case they are outside the group.See picture.
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
      • I Offline
        ik2012
        Thanks so much Gaieus and voljanko! Also a big thanks to thomthom for the awesome plugin!
          Hi jean-françois and welcome!
          The file is a simple ruby plugin (a text file) that you have to copy into this folder:
          C:\Program Files\Google\Google SketchUp 8\Plugins
          Also, there is a plugin library you will need (linked from the first post, above the attached plugin). It is a zipped library of several files. Unzip the archive onto your desktop, go into the folder that is created there and copy everything as you see there into the same plugin directory as above.
          Restart SU and find the plugin under the Tools menu.
            @jean-françois said:
            I would like to install the solid inspector plugin on my computer.
            Can you explain me how to do it?
            Thanks in advance
            I've written a tutorial on how to install plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
            Even includes link to an installer utility that will make it easier to install them.
              jean-françois
              Subject: [Plugin] Solid Inspector (1.1.0) — 30 June 2011
              Thanks in advance
              Hi Guys, thanks for your answers. I am still facing some problems.
              I copied and unzip the file TT_lib2 into the folder "c/...sketchup8/plugins"
              I also copied the file TT_solid_inspector.rb in the same folder.
              I closed and restared SU but I get a window with "load error messages" everytime I open SU.
              Moreover, when I click on the tools Bar, I see "solid tools (pro only)->" but I can't click on it.
              I do not use SU pro, is it the reason of the problem?
              Thanks in advance
              Jean-François
                archzag
                Geniale!
                  Rich5
                  How do you get out of solid inspector? Prob a very dumb question but it seems once on I can't get out and back to SU.
                    Have you tried picking another tool?
                      Just activate another tool, like Select (Spacebar).
                        d12dozr
                        Just curious, why are some errors highlighted red, and some yellow? I haven't been able to figure out a pattern.
                        http://goo.gl/f7ooYh
                          Red is the currently selected error. I think you can press a key (Return maybe=) to make it zoom in. You can also Tab around between errors.
                          There is lots of room for improvement - but not enough time... 😞
                            d12dozr
                            Oh cool, I knew about the Tab key, but I never knew about the colors.
                            Its an excellent tool - thanks again!
                              thegreek87
                              Wish I knew about this plugin sooner, gonna save me a lot of time. Thank you very much 😄
                              http://www.nicholasvaisey.co.uk/.
                              • DesertRavenD Offline
                                DesertRaven
                                Hey TomTom, this is an awesome tool!!! thank you so much for sharing this.
                                A note to the Sketchup Programmers, weather they will read this or not, just have to say it:
                                Did it never occur to you that something like this should of been in the solid tool kit to begin with?!!
                                Do you guys ever test what you program? Put a little bit more muscle in to it, please for crying out loud!
                                Also try and make us some tools that don't leave fractions of tiny lines behind like that buggy follow me tool, fix it already!
                                Thanks. I just donated $50 to ThomThom. Keep the good work going!
                                simplicity is the ultimate sophistication
                                • V Offline
                                  VeniVidiVici
                                  Hi Thomas,
                                  Thank you again for this tool (belive I've said it before) great tool.
                                  I haven't used it in a while, and now I cant seem to get it working.
                                  It seems to load fine but nothing happens?
                                  I've double checked, and it is in the google sketchup 8 plugins folder...
                                  tt_solid_inspector.rb
                                  I also put in the newest TT_Lib2, which is in its own folder in the Plugins directory.
                                  I still cant seem to get anything to work, I have a few objects that arent quite solids, grouped, and it loads
                                  but I see no errors, yet it is not a solid.
                                  Any ideas?
                                  Thanks!
                                  • V Offline
                                    VeniVidiVici
                                    Thomas, your tools are awesome...I got it to work, not sure what it was, guess I just needed a reboot?!
                                    This tool has saved me countless hours of work...I will be contributing in the near future...tks again.
                                    • Brett
                                      Any ideas?
                                      I don't have an idea as of yet - you need to be more specific to what "doesn't work". No menus? Tool doesn't activate?
                                      You see errors you say, in the Ruby Console? (If so, please post them - they would be extremely useful)
                                      • xiombargX Offline
                                        xiombarg
                                        It's actually cool to see people making donations to valued plugin programmers. I'm working through a prototyping, but as soon as I make any money, I'm committed to donate accordingly.
                                        • voljankoV Offline
                                          voljanko
                                          Maybe you have ungroupped items mixed with grouped one.
                                          To detect this you need a SuSolid plugin (free for only solid inspections).
                                          David
                                            Snowy
                                            Thanks a lot! Great plugin
                                            • 6
                                            • 7
                                            • 8
                                            • 15
                                            • 16
                                            • 6 / 16
