    [Plugin] Solid Inspector
    303 Posts 99 Posters 312.0k Views 98 Watching
      PapaBear60
      OK, thanks for the heads-up on Cut List, but how could you tell from the picture I sent?
        By the name. The current version would show as "cutlist.rb".
        • E Offline
          eraeya
          Just wanted to say: this plugin is the biggest thing to happen since hotdogs. Hurray for workflow!
            KJGC
            Very, VERY impressive application! Thom you've made my work so much easier, and for that I am truly grateful. This "Error GPS" is remarkable, thank you so much for the amount of time and effort you've put into this plugin, in order of making everyone elses life T-H-A-T M-U-C-H easier. Merci mon amis !
            Sincerely,
            Kyle James
                Now thatwas a proper "thank you". 😉
                • I Offline
                  ik2012
                  Hi, kind of a sketchup newbie here. I am using this plugin to check my model for water tightness, but I am having trouble understanding the output. Would anyone mind looking at these screen shots and giving me some tips? Thanks!
                  bottle base top.skp
                    In order to build a solid object, there cannot be inner faces (amopng other conditions). You have some - and that's still not the only reason as deleting the face in the screenshot below still does not fix it.
                    (Note that I have reversed some faces and smoothed the group generally...)
                    As it turns out, it was all inner faces. Did not take too long to fix: when you have some time, send ThomThom a cookie.
                    bottle base top.skp
                    • voljankoV Offline
                      voljanko
                      There are also some ungrouped lines that can prevent your model to be solid.That means that they are outside the group or inside the group with the solid subgroup.In your case they are outside the group.See picture.
                      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
                      • I Offline
                        ik2012
                        Thanks so much Gaieus and voljanko! Also a big thanks to thomthom for the awesome plugin!
                          Hi jean-françois and welcome!
                          The file is a simple ruby plugin (a text file) that you have to copy into this folder:
                          C:\Program Files\Google\Google SketchUp 8\Plugins
                          Also, there is a plugin library you will need (linked from the first post, above the attached plugin). It is a zipped library of several files. Unzip the archive onto your desktop, go into the folder that is created there and copy everything as you see there into the same plugin directory as above.
                          Restart SU and find the plugin under the Tools menu.
                            @jean-françois said:
                            I would like to install the solid inspector plugin on my computer.
                            Can you explain me how to do it?
                            Thanks in advance
                            I've written a tutorial on how to install plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                            Even includes link to an installer utility that will make it easier to install them.
                              jean-françois
                              Subject: [Plugin] Solid Inspector (1.1.0) — 30 June 2011
                              Thanks in advance
                              Hi Guys, thanks for your answers. I am still facing some problems.
                              I copied and unzip the file TT_lib2 into the folder "c/...sketchup8/plugins"
                              I also copied the file TT_solid_inspector.rb in the same folder.
                              I closed and restared SU but I get a window with "load error messages" everytime I open SU.
                              Moreover, when I click on the tools Bar, I see "solid tools (pro only)->" but I can't click on it.
                              I do not use SU pro, is it the reason of the problem?
                              Thanks in advance
                              Jean-François
                                archzag
                                Geniale!
                                  Rich5
                                  How do you get out of solid inspector? Prob a very dumb question but it seems once on I can't get out and back to SU.
                                    Have you tried picking another tool?
                                      Just activate another tool, like Select (Spacebar).
                                        d12dozr
                                        Just curious, why are some errors highlighted red, and some yellow? I haven't been able to figure out a pattern.
                                        http://goo.gl/f7ooYh
                                          Red is the currently selected error. I think you can press a key (Return maybe=) to make it zoom in. You can also Tab around between errors.
                                          There is lots of room for improvement - but not enough time... 😞
                                            d12dozr
                                            Oh cool, I knew about the Tab key, but I never knew about the colors.
                                            Its an excellent tool - thanks again!
                                            • 15
                                            • 16
                                            • 6 / 16
