    [Plugin] Solid Inspector
    303 Posts 99 Posters 342.4k Views 98 Watching
      By the name. The current version would show as "cutlist.rb".
      • E Offline
        eraeya
        Just wanted to say: this plugin is the biggest thing to happen since hotdogs. Hurray for workflow!
          KJGC
          Very, VERY impressive application! Thom you've made my work so much easier, and for that I am truly grateful. This "Error GPS" is remarkable, thank you so much for the amount of time and effort you've put into this plugin, in order of making everyone elses life T-H-A-T M-U-C-H easier. Merci mon amis !
          Sincerely,
          Kyle James
              Now thatwas a proper "thank you". 😉
              • I Offline
                ik2012
                Hi, kind of a sketchup newbie here. I am using this plugin to check my model for water tightness, but I am having trouble understanding the output. Would anyone mind looking at these screen shots and giving me some tips? Thanks!
                bottle base top.skp
                  In order to build a solid object, there cannot be inner faces (amopng other conditions). You have some - and that's still not the only reason as deleting the face in the screenshot below still does not fix it.
                  (Note that I have reversed some faces and smoothed the group generally...)
                  As it turns out, it was all inner faces. Did not take too long to fix: when you have some time, send ThomThom a cookie.
                  bottle base top.skp
                  • voljankoV Offline
                    voljanko
                    There are also some ungrouped lines that can prevent your model to be solid.That means that they are outside the group or inside the group with the solid subgroup.In your case they are outside the group.See picture.
                    SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
                    • I Offline
                      ik2012
                      Thanks so much Gaieus and voljanko! Also a big thanks to thomthom for the awesome plugin!
                        Hi jean-françois and welcome!
                        The file is a simple ruby plugin (a text file) that you have to copy into this folder:
                        C:\Program Files\Google\Google SketchUp 8\Plugins
                        Also, there is a plugin library you will need (linked from the first post, above the attached plugin). It is a zipped library of several files. Unzip the archive onto your desktop, go into the folder that is created there and copy everything as you see there into the same plugin directory as above.
                        Restart SU and find the plugin under the Tools menu.
                          @jean-françois said:
                          I would like to install the solid inspector plugin on my computer.
                          Can you explain me how to do it?
                          Thanks in advance
                          I've written a tutorial on how to install plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                          Even includes link to an installer utility that will make it easier to install them.
                            jean-françois
                            Subject: [Plugin] Solid Inspector (1.1.0) — 30 June 2011
                            Thanks in advance
                            Hi Guys, thanks for your answers. I am still facing some problems.
                            I copied and unzip the file TT_lib2 into the folder "c/...sketchup8/plugins"
                            I also copied the file TT_solid_inspector.rb in the same folder.
                            I closed and restared SU but I get a window with "load error messages" everytime I open SU.
                            Moreover, when I click on the tools Bar, I see "solid tools (pro only)->" but I can't click on it.
                            I do not use SU pro, is it the reason of the problem?
                            Thanks in advance
                            Jean-François
                              archzag
                              Geniale!
                                Rich5
                                How do you get out of solid inspector? Prob a very dumb question but it seems once on I can't get out and back to SU.
                                  Have you tried picking another tool?
                                    Just activate another tool, like Select (Spacebar).
                                      d12dozr
                                      Just curious, why are some errors highlighted red, and some yellow? I haven't been able to figure out a pattern.
                                      http://goo.gl/f7ooYh
                                        Red is the currently selected error. I think you can press a key (Return maybe=) to make it zoom in. You can also Tab around between errors.
                                        There is lots of room for improvement - but not enough time... 😞
                                          d12dozr
                                          Oh cool, I knew about the Tab key, but I never knew about the colors.
                                          Its an excellent tool - thanks again!
                                            thegreek87
                                            Wish I knew about this plugin sooner, gonna save me a lot of time. Thank you very much 😄
                                            http://www.nicholasvaisey.co.uk/.
                                            • 15
                                            • 16
                                            • 6 / 16
