    [Plugin] TT_Lib²
    310 Posts 66 Posters 417.7k Views 66 Watching
    • TIGT Online
      Being an administrator does not guarantee full security permissions to folders within the Program Files tree. By default everyone gets 'read-only'.
      So you need to select the Plugins folder's icon:
      right-click
      context-menu
      Properties
      Security
      Edit...
      and give every entry FULL permissions
      Apply/OK.
      Also in the same folder as the Plugins folder find SketchUp.exe, select it and:
      right-click
      context-menu
      Properties
      Compatibility
      Tick the 'Always run as administrator' box...
      Apply/OK.
      Also make sure that the Plugins folder does not have a custom icon - this is known to have subtle effects on permissions that report FULL but are really slightly reduced 😒
      • tt_suT Offline
        tt_su
        After you removed the content of the VirtualStore Plugins folder - did you also remove it?
        (I might have to change the detection code to not raise a message if the folder exist but is empty. At the moment it will alter the user by just being there.)
        • micioneM Offline
          micione
          Thomas,
          The procedure indicated by TIM has been active for a long time on my computer.
          The folder "virtual store" is empty.
          But the warning reappears always, to the opening of SU8.
          Earlier Library, as well as all installed plugins, do not have
          given problems.
          In SU2013, the question does not arise. The thing does not happen.
          • G Offline
            g_wilson
            @tt_su said:
            Thanks for the feedback. I think I have a fix - but I don't have an XP machine to test on.
            I've uploaded a new version on BitBucket: https://bitbucket.org/thomthom/tt-library-2/downloads
            Can you try that and let me know if it works. Then I can upload it to the Plugin Store and Extension Warehouse.
            Hi - 2.9.2 same Load Errors as 2.9.1 Tried change rbz => zip => unpacked => copied to "plugins" and also installed directly thru Preferences as rbz. Same results. Also deleting TT_lib folder and .rb before installing 2.9.2.
            I guess the time is coming to change OS to something that doesn't require the use of hi grade metallurgical anthracite.
            Error Loading File tt_cleanup.rb
            can't convert nil into StringError Loading File tt_shell.rb
            can't convert nil into StringError Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/tt_solid_inspector/core.rb
            can't convert nil into StringError Loading File tt_solid_inspector.rb
            From Ruby Console:
            ENV.each { |k,v| puts "#{k} = #{v}" }
            ALLUSERSPROFILE = C:\Documents and Settings\All Users
            APPDATA = C:\Documents and Settings\Gary\Application Data
            CLIENTNAME = Console
            CommonProgramFiles = C:\Program Files\Common Files
            COMPUTERNAME = GARY-48BB76102C
            ComSpec = C:\WINDOWS\system32\cmd.exe
            FP_NO_HOST_CHECK = NO
            HOMEDRIVE = 😄
            HOMEPATH = \Documents and Settings\Gary
            LOGONSERVER = \GARY-48BB76102C
            NUMBER_OF_PROCESSORS = 2
            OS = Windows_NT
            Path = C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared;C:\WINDOWS\system32\WindowsPowerShell\v1.0
            PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
            PROCESSOR_ARCHITECTURE = x86
            PROCESSOR_IDENTIFIER = x86 Family 15 Model 67 Stepping 3, AuthenticAMD
            PROCESSOR_LEVEL = 15
            PROCESSOR_REVISION = 4303
            SESSIONNAME = Console
            SystemDrive = 😄
            SystemRoot = C:\WINDOWS
            TEMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
            TMP = C:\DOCUME~1\Gary\LOCALS~1\Temp
            USERDOMAIN = GARY-48BB76102C
            USERNAME = Gary
            USERPROFILE = C:\Documents and Settings\Gary
            windir = C:\WINDOWS
            {"ALLUSERSPROFILE"=>"C:\Documents and Settings\All Users", "APPDATA"=>"C:\Documents and Settings\Gary\Application Data", "CLIENTNAME"=>"Console", "CommonProgramFiles"=>"C:\Program Files\Common Files", "COMPUTERNAME"=>"GARY-48BB76102C", "ComSpec"=>"C:\WINDOWS\system32\cmd.exe", "FP_NO_HOST_CHECK"=>"NO", "HOMEDRIVE"=>"C:", "HOMEPATH"=>"\Documents and Settings\Gary", "LOGONSERVER"=>"\\GARY-48BB76102C", "NUMBER_OF_PROCESSORS"=>"2", "OS"=>"Windows_NT", "Path"=>"C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared\;C:\WINDOWS\system32\WindowsPowerShell\v1.0", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1", "PROCESSOR_ARCHITECTURE"=>"x86", "PROCESSOR_IDENTIFIER"=>"x86 Family 15 Model 67 Stepping 3, AuthenticAMD", "PROCESSOR_LEVEL"=>"15", "PROCESSOR_REVISION"=>"4303", "ProgramFiles"=>"C:\Program Files", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\WINDOWS", "TEMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "TMP"=>"C:\DOCUME~1\Gary\LOCALS~1\Temp", "USERDOMAIN"=>"GARY-48BB76102C", "USERNAME"=>"Gary", "USERPROFILE"=>"C:\Documents and Settings\Gary", "windir"=>"C:\WINDOWS"}
              @micione said:
              Thomas,
              That's because the previous versions would simply check if there was a Plugins folder in the VirtualStore. It didn't check if it was empty.
              I just uploaded a new version that checks if there actually is files there before warning. I think that should fix this.
                Wait - these are different errors... don't think that is related to the VirtualStore.
                All these errors refer to other plugins.
                What's the output if you open the Ruby Console and type in: load 'tt_cleanup.rb' ?
                • micioneM Offline
                  micione
                  Thomas,
                  The new version 2.9.3 seems to have solved the problem.
                  Thank you.
                  • G Offline
                    g_wilson
                    Hi again - this may be a wild goose chase. I just closed SU8 and after exiting - up pops bugsplat window. I have attached .dmp file - closed bugsplat without being smart enough to send to trimble but searched out .dmp file. I tried 4 times to repeat bugsplat but no joy - exited cleanly. The bugsplat occurred with a new blank my default .skp as per usual.
                    OOPS - won't send .dmp file - renamed .txt
                    Stubborn bloody thing - now attached as .zip
                    SketchUpLUA15091.zip
                    • G Offline
                      g_wilson
                      Per request RESULT:
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:27: warning: already initialized constant BB_LEFT_FRONT_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:28: warning: already initialized constant BB_RIGHT_FRONT_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:29: warning: already initialized constant BB_LEFT_BACK_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:30: warning: already initialized constant BB_RIGHT_BACK_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:31: warning: already initialized constant BB_LEFT_FRONT_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:32: warning: already initialized constant BB_RIGHT_FRONT_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:33: warning: already initialized constant BB_LEFT_BACK_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:34: warning: already initialized constant BB_RIGHT_BACK_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:36: warning: already initialized constant BB_CENTER_FRONT_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:37: warning: already initialized constant BB_CENTER_BACK_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:38: warning: already initialized constant BB_CENTER_FRONT_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:39: warning: already initialized constant BB_CENTER_BACK_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:41: warning: already initialized constant BB_LEFT_CENTER_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:42: warning: already initialized constant BB_LEFT_CENTER_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:43: warning: already initialized constant BB_RIGHT_CENTER_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:44: warning: already initialized constant BB_RIGHT_CENTER_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:46: warning: already initialized constant BB_LEFT_FRONT_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:47: warning: already initialized constant BB_RIGHT_FRONT_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:48: warning: already initialized constant BB_LEFT_BACK_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:49: warning: already initialized constant BB_RIGHT_BACK_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:51: warning: already initialized constant BB_LEFT_CENTER_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:52: warning: already initialized constant BB_RIGHT_CENTER_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:53: warning: already initialized constant BB_CENTER_FRONT_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:54: warning: already initialized constant BB_CENTER_BACK_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:55: warning: already initialized constant BB_CENTER_CENTER_TOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:56: warning: already initialized constant BB_CENTER_CENTER_BOTTOM
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:58: warning: already initialized constant BB_CENTER_CENTER_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:59: warning: already initialized constant BB_CENTER
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:64: warning: already initialized constant MB_ICONHAND
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:65: warning: already initialized constant MB_ICONSTOP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:66: warning: already initialized constant MB_ICONERROR
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:67: warning: already initialized constant MB_ICONQUESTION
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:68: warning: already initialized constant MB_ICONEXCLAMATION
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:69: warning: already initialized constant MB_ICONWARNING
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:70: warning: already initialized constant MB_ICONASTERISK
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:71: warning: already initialized constant MB_ICONINFORMATION
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:72: warning: already initialized constant MB_ICON_NONE
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:74: warning: already initialized constant MB_DEFBUTTON1
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:75: warning: already initialized constant MB_DEFBUTTON2
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:76: warning: already initialized constant MB_DEFBUTTON3
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:77: warning: already initialized constant MB_DEFBUTTON4
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:82: warning: already initialized constant MESH_SHARP
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:83: warning: already initialized constant MESH_SOFT
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:84: warning: already initialized constant MESH_SMOOTH
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:85: warning: already initialized constant MESH_SOFT_SMOOTH
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:90: warning: already initialized constant POINT_OPEN_SQUARE
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:91: warning: already initialized constant POINT_FILLED_SQUARE
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:92: warning: already initialized constant POINT_CROSS
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:93: warning: already initialized constant POINT_X
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:94: warning: already initialized constant POINT_STAR
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:95: warning: already initialized constant POINT_OPEN_TRIANGLE
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:96: warning: already initialized constant POINT_FILLED_TRIANGLE
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:114: warning: already initialized constant VERSION
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:118: warning: already initialized constant PREF_KEY
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:121: warning: already initialized constant PATH
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:122: warning: already initialized constant PATH_LIBS
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:125: warning: already initialized constant PATH_LIBS_CEXT
                      Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:249:in virtualstore_check'
                      C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:450
                      C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89:in require' C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:89 (eval):232:in load'
                      (eval):232
                      • tt_suT Offline
                        tt_su
                        @micione said:
                        Thomas,
                        Thank you.
                        So this crash doesn't repeat itself?
                        Have you also tried the latest 2.9.3 version? Are things working better then?
                        • tt_suT Offline
                          tt_su
                          hm.... this might be yet another bug. Let me just quickly update with a new patch.
                          (I wish I had access to an XP machine right now...) 😞
                            Ok - version 2.9.4 up for grabs!
                            (And at the PluginStore - I think - if I managed to update that correctly...)
                            Update bonanza... 😒
                            • G Offline
                              g_wilson
                              Yes - I tried 2.9.3 - same result.
                              Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in exist?': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:90 C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:250:in virtualstore_check'
                              C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:454
                              (eval):232
                              • G Offline
                                g_wilson
                                SUCCESS !!! Thank you Thomas. Have nominated you for the "TIG" award for fast service.
                                • tt_suT Offline
                                  tt_su
                                  Whohoo! Sorry for the inconvenience - had I had a copy of XP it would have been fixed earlier.
                                  • irwanwrI Offline
                                    irwanwr
                                    Thank you very much, Thomas.
                                    Love you 😄
                                    I don't know how to do this though;
                                    @tt_su said:
                                    Hmm... must be some differences in the environment variable between Win8/7/Vista and XP.
                                    Can you open the Ruby Console and give me the result of ENV.each { |k,v| puts "#{k} = #{v}" } ? Then I can make a patch for this.
                                    Thanks to Gary Wilson for the help 😄
                                    • tt_suT Offline
                                      tt_su
                                      irwanwr: did 2.9.4 fix the error message you where getting?
                                      • guanjinG Offline
                                        guanjin
                                        2.9.4+Selection_Toys,In Sketchup8 windows XP, open the dialog, automatic sketchup8 quit after tens of seconds, without any prompting。
                                        Edge Tools,Can not be used, loading errors。
                                        I come from China, is to learn
                                        • tt_suT Offline
                                          tt_su
                                          That is strange. I cannot reproduce that. By the way, Selection Toys has never used TT_Lib2. I used TT_Lib1 for a while - but I made it stand-alone earlier this year. What version of Selection Toys do you have? And if you have only Selection Toys loading, does it still crash?
                                          What are these loading errors? (I can't do much without them.) Also, what version of Edge Tools.
                                          • guanjinG Offline
                                            guanjin
                                            Selection Toys loading2.36 Edition。
                                            UV Toolkit v2.31
                                            Are not available。Earlier versions without problems。
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
